#41
Thanks Fill, That sure throws me a monkey wrench!!!!!!!!!!!!"Bill"! For sure orig.??
How is bigpop??? No contact for months!! |
#42
REALLY?
Hate to break the news to you but your 65 will probably fail in all categories.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
#43
I just rolled through my files of six Original M/T 65's and they all have the two bellows boot. 12A BF 12E BAL 02B PON 3A BF 06D PON 06E PON Note, no KAS cars on my list so possibly a supplier to that plant had a different style boot?
#44
The judges will tell me "that is not the correct current reproduction part".
#45
slotted nuts
where can I get the slotted nuts on the linkage? does anybody have some for sale thanks.bob. not salted nuts.
#46
they are called Marsden nuts Google it
#47
How many do you want? I have 1/4-20 and/or 1/4-28.
#48
In the judging score sheets, I see this comment used alot: "should show signs of age and use", but most concours cars look to be better than new. That comment seems to contradict what you see in the field of show cars.
#49
That would be for original class not restored class . if found you have new or repro stuff I'm thinking it's a point or so. on a non restored or survivor car.
#50
dld, did you see any 64-66 original survivors being judged in your recent car show?
#51
there was a 66 i noticed . a black car . then there also was a 65 original owner car unrestored in the lobby ( very nice to look at for me ). both where they fielded the featured cars. may have been other years but did not pay to much attention un less they were on the way to the beer or mens room
#52
#53
Another question on the carb base hex nuts; MPC shows 3722860 and (310-M). Do these numbers mean something to someone, or just generic?? "Bill"!
#54
As long as the carb base hex nuts are standard SAE length, 1/2" hex, and colored black, there should not be a problem.
I had no points deducted on my Tripower by GTOAA at Dayton last year. I do have the correct plug wire holder now, however. Here's how mine looked then--studs and nuts, etc.
#55
judging
dick I will send you an email. thanks bob.
#56
I don`t wish to get into an argument over "nuts" but Marsden nuts, although similar to the factory look of the throttle attaching hardware, is not the nut that was used. the Marsden nuts are a NON LOCKING nut and perhaps not a good choice for safety here. The correct factory nuts are called split beam, split hex, or slotted beam. They of course are self locking and originally developed for the military. The design is also reusable holding their tension several removal cycles. The slotted or split end is slightly squeezed and provides a "bind" to the threads thus locking the nut to the threaded bolt. Several external designs are available, with some looking very close to a slotted crown nut and others similar to a standard slotted nut.(AGAIN many styles) The visual giveaway is the PAPER thin slots and bind of the thread about halfway into the nut. In NO way can a cotter key or pin be used. Marsden nuts typically have wider slots and NO bind to the threads. Without a lock washer, the Marsden is not a safe fastener and very prone to backing off when exposed to vibration.
Hard to find, the split beam nuts are out there. I had a price of 67.84 quoted on 100. (I just don`t want 100) |
#57
judging
http://www.lok-mor.com/mar-loc.html
http://www.amkproducts.com/bulk2.asp...e=Marsden+Nuts http://www.dalecompany.com/GREER_STOP_NUT_Locknut.html http://titanfasteners.com/items.aspx...D+-+UNF&id=113 very posable the oe were different cad plating im sure , may be of different style also. think I found mine used at Carlisle in a box of bolts a vendor had . when I got my carbs back from M. Wesson he had the wrong bolts in. Last edited by dld; 08-07-2014 at 06:02 PM. |
#59
War Eagle is right in saying that the original slotted nuts used on the linkage and various other parts of our old Pontiacs had very thin slots. Most of those you see today have wider slots, but all of them are designed to be self-locking. Both types are available, but in the 1/4-28 size, the narrow-slotted type is very not easy to find and sometimes quite expensive since most vendors sell only lots of 100 pc. or $50 min.
Only one of the vendors in the post above has 1/4-28 nuts. The other vendors list only 3/8" and larger thread size. If you examine either the wide slot or narrow slot type, you'll see on the bottom side (that contacts the surface to be secured), there is a chamfer or relief next to the threads. When the nut is tightened, this relief causes the nut to distort and squeeze the slotted area tight against the male threads. So, functionally, the Marsden nuts are fine. If you need complete originality, the thin slotted version is available. Some of us regularly criticize the Corvette guys for being very exacting, but we're becoming more like that group every year! When my '64 GTO was judged by GTOAA, no points were deducted for the wider-slot Marsden nuts.
#60
Dick B
Speaking of details you did not answer my question on the date coding of hose clamps . Did they look to see if you had dates on yours. They did mine and i did not |
