Old 09-24-2003, 03:49 AM
Will Will is offline
More pics and a writeup for anyone interested at this website:
http://garage.willbaker.com/73bird/WS6wheels.html
'73 Firebird 400/4-speed Black on Black, mix & match.
Old 09-24-2003, 04:30 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Looks good. And you have a LOT of wheel options with those adaptors. I wonder if those would work on a GTO? Hmmmm. Because I want to use 17" on my 66 GTO but I have no idea what size and backspacing to use and what tire sizes to get.
I am thinking 17X8 with 245/45/17 tires most likely but I don't know what backspacing.
I am going to be useing probably 13" rotors and 4 piston calipes up front and a Baer kit out back.
Old 09-24-2003, 06:39 AM
Givindabird Givindabird is offline
,did I mention ?Very nice!!
It ain't no feakin' camaro!
Merry Christmas,Happy Halloween, God bless America, and my Mother and Father.If you don't like your freedoms,ignore them and they'll go away!
Old 09-24-2003, 06:56 AM
gto_guy gto_guy is offline
Very nice car and Mr GTO you should use 4 1/2 backspacing with the 17`s.No adapters needed.
www.cardomain.com/id/gto_guy
Everyone should believe in something,I believe I`ll have another drink.
Old 09-24-2003, 07:59 AM
fast1970transam's Avatar
fast1970transam fast1970transam is offline
Nice
I'm never gonna dance again
Guilty feet have got no rhythm
Though it's easy to pretend
I know your not a fool
Old 09-24-2003, 02:33 PM
Formula400NYC Formula400NYC is offline
Looks real good Will. Do you know if those adapters would work with Vette rims? There are some C4 and C5 rims that would look great on 71 Formula. Thanks, Jerry
Old 09-24-2003, 07:13 PM
JoDurhamRA1972Goat455 JoDurhamRA1972Goat455 is offline
is that the same wheel that is on the newer GP's? I wondered what it would look like on a GTO.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>sorry, I didn't realize you were so close. <HR></BLOCKQUOTE>
Live on, live it up today
This life’s your cup
So drink it up I say, yeah
Say it’s mine so give it all up to me now
And walk that line, don’t let this go, drink it up!
3DD.
Old 09-24-2003, 08:09 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by gto_guy:
Very nice car and Mr GTO you should use 4 1/2 backspacing with the 17`s.No adapters needed<HR></BLOCKQUOTE>
I'm running 17X8s with 4-1/2" backspace (zero offset) on my '64 Tempest, they fit pretty well with 235/45-17s all around. I had them built so they would give the car a wider track and I wanted a sort of 'deep dish' look for the wheels.
But to fit a bigger tire like a 245 up front without rubbing on big bumps I think 4-3/4" or 5" backspace would be better. Running a 4-1/2" backspace sort of limits the tire size a bit, in hindsight I wish I had gone for at least 4-3/4" backspace.
But hey, I can't complain too much.
Oh, nice job on fitting your wheels up Will.
Old 09-25-2003, 12:43 AM
Thanks everybody! It's good to know I'm not the only one who likes the look of these wheels.
Jerry G - yes, these adapters will work with C4 and C5 wheels. In fact, that's what VB&P used to advertise them for - putting C4 16x9" wheels on 2nd gens. However, you may need a different thickness depending on the exact backspacing of the wheel you go with. Best to get the wheels first then order the adapters that will give you the backspacing you need. I've seen 17x9" C4 wheels put on a '69 'bird using these adapters.
I used a set of 3/4" thick adapters to put 16x8" IROC camaro wheels on my '75 Nova. The IROC wheels have 4.75" backspacing on the front wheels and 5.5" on the rears which was too much for the Nova. With an 8" wheel, 4.75" worked perfect on that car. However, I did have to grind the recesses between the stud holes in the IROC wheels so the spacer's lugnuts would fit.
JoDurham, I do not believe these wheels are the same as the GP wheels. Pretty sure the GP wheels aren't as wide, and they may have a different (smaller) bolt pattern. Actually, I didn't know GM put 17" wheels on the GP's, I thought they were all 16" but then again, my knowledge of modern GPs is limited to my experience driving one for a week as a rental car and watching other people drive them down the track.
Old 10-03-2003, 09:43 PM
R 70 Judge's Avatar
Photo shop job
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 10-10-2003, 02:03 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Man those blue wheels on the white TA look cool.
On a second gen the '89 16" lace WS6 wheels fit fine with 255-50-16s even using "rears" on the rear.
Skip Fix
