Old 10-01-2022, 09:08 PM
slowbird's Avatar
slowbird slowbird is online now
Originally Posted by J.C.you View Post
Any dyno sheets to back the 1350 you claim?
Not claiming anything just saying they fall in that range.
Old 10-01-2022, 09:53 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Info from PZ? No dyno numbers, just talk.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 10-06-2022, 09:18 AM
Fast Floridian's Avatar
Fast Floridian Fast Floridian is offline
Default pump gas 535
my 535 10.25 to 1 pump gas street car made 865 on the dyno at 6200 floating valves upgrading springs and making some changes hoping to see 1000hp on pump gas at 7500 and drive it on the street. Trying to get ready to cruize down to Turkey rod run end of this month.
The Following 2 Users Say Thank You to Fast Floridian For This Useful Post:
Old 10-06-2022, 06:30 PM
Scott Stoneburg's Avatar
That's great power. What heads? Tiger?
Old 10-06-2022, 06:55 PM
slowbird's Avatar
I don't go on PZ, Langer backed up my statement, he falls in that range, others fall in that range as well.
Old 10-06-2022, 06:56 PM
slowbird's Avatar
Any details on engine?
Old 10-06-2022, 06:58 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
There is at least one other I know of in the 1300 range.
Old 10-13-2022, 10:54 AM
Default 535 trying to 1000 hp pump gas
dual holley 950 xp with tunnel ram custom built by Dave H & M airflow and machine.
wide port Edelbrocks 72 cc with custom chambers. NJK r5671a-8 plugs. ROSS custom dish pis 2.39 1.72 chrysler size valves
MRA1 Block.ATI Balancer oliver steel rods Scat ultra light crank 55mm custom solid comp cams cam, street solid crower offset rockers comp push rods All head work and intake design by Dave at H&M Machine. Headers custom 2.25 primary 4 inch tuned collector into 3.5 exhaust push button to open exit at the collector built by performance exhaust. Machine work and assembly performed by Gary Harrison of Jacksonville florida. 4.375 bore 4.5 stroke
Old 10-13-2022, 09:27 PM
rce4mny rce4mny is offline
Default 525 1000 hp
can you give specifics on cam size and flow for heads.
