Old 09-07-2020, 08:38 PM
6t5gto 6t5gto is offline
Default Factory undercoating
Did all 65 GTOs come with undercoating in the quarter panel wheelhouses standard even if the full underbody undercoating was chosen? What about the backside of the fenders that you can see from the motor compartment?
Old 09-07-2020, 08:58 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
All the 65's I've owned (a dozen or so) had the undercoating on the outer sides of the trunk pan behind the rear wheelhouses. The rear wheelhouses themselves were undercoated regardless of where dealer undercoating was applied. Also there was undercoating in the transmission tunnel. I've never seen any undercoating in or around the front wheelhouses. Also never seen any on the backside of the front fenders.
Old 09-07-2020, 09:53 PM
Jerry, when you say "outer sides of the trunk pan" do you also mean the lower rear section of the quarter panel?
Old 09-08-2020, 07:12 PM
RA1John RA1John is offline
FWIW...
What the factory applied was technically referred to as sound deadener.
Depending on year & plant, some processes varied.
Qtr. Wheel House inner.
Qtr. Inner below qtr. glass.
Door inner (inside of outer)
Trunk drop off
Bottom of trunk extension
Fender Skirt (inner)
Since all were manually sprayed, coverage varied.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 09-08-2020, 09:06 PM
Jerry H.'s Avatar
Yes
