Old 04-03-2024, 10:17 PM
Tim Corcoran's Avatar
Silly me, I was going to have the spring seats machined. I took my heads to my machinist to have them machined and walked out with a set of +.050 valve locks. I'll put them on the exhaust valves only.
Tim Corcoran
Old 04-03-2024, 10:39 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
those usually work just double check rocker still contacts valve tip seem retainers it moves up too much.
Skip Fix
Old 04-04-2024, 12:39 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... There’s only one way to correctly answer that...
I would say that only the designer of the cam profiles can correctly answer the spring force [not "pressure"} questions. Values such as peak negative acceleration aren't usually available to end users.
Old 04-04-2024, 09:48 PM
The designer of the cam is gone now but, Bullet knows Ultraydyne cams as well an anybody . Tim at Bullet worked for Harold for several years. Bullet highly recommended to run 1.65 and they recommended the springs too.
Tim Corcoran
Old 04-04-2024, 10:23 PM
Yeah I already check the clearance and it's good. My machinist made the same recommendation. Thanks
Tim Corcoran
