Old 08-07-2018, 06:00 PM
455hota's Avatar
455hota 455hota is offline
Default Anyone know these clips?
ID:	489761Click image for larger version
I was in my box of extra / unknown parts today and came across these clips. One is slightly deformed but they are exactly the same. Both have a P stamped on one side. But they both have no captured nut or threads of any kind. Also I see no evidence that there was a welded on nut.
Are these related to core support, or possibly front bumper brackets/subframe?
Thanks.
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 08-07-2018, 10:57 PM
Formulabruce's Avatar
They Look like a type with a nut welded on one side.
Old 08-08-2018, 05:59 AM
455hota's Avatar
Formula Bruce, if they are supposed to have a nut welded to them, where were they used?
...Steve T.
Old 08-08-2018, 11:13 AM
Formulas Formulas is offline
To me they look like an assy aid vrs an anchor point something like around a carpet hole for a seat belt bolt, something LIKE that
Old 08-08-2018, 12:39 PM
Possible fender? the hole size is big.
Old 08-08-2018, 09:17 PM
FunctionalShaker FunctionalShaker is offline
70 Core support to subframe.
Name:	Core Support Hardware.jpg
ID:	489878   Click image for larger version
Name:	P.S. Core to Subframe Mount.jpg
Old 08-09-2018, 08:25 AM
455hota's Avatar
This is great info! They were in my core support hardware bag.
But from the second picture I can’t see exactly the location. Appears the square washer with the tab gets the clip with the nut. Not sure exactly where this clip goes. On the actual core support?? But what is it’s purpose?Maybe I can see from the assembly manual pics.
...Steve T.
Old 08-09-2018, 10:14 AM
Yeah, the pic's not that clear. I think you can see it in the assy. Manual. I've got a loose set I can take a pic of later today.
Old 08-09-2018, 04:27 PM
455hota's Avatar
Ok thanks!
...Steve T.
Old 08-09-2018, 06:28 PM
Here you go. They clip the assembly onto the subframe.
ID:	489969   Click image for larger version
Old 08-09-2018, 06:32 PM
455hota's Avatar
Thanks!
So it actually holds the square tabbed cup and nut in place on the frame, until the bolt (which is captured to the biscuit via another clip), is threaded in place.
Now I have the rest of the story...
...Steve T.
Old 08-10-2018, 09:37 AM
tonyk tonyk is offline
On both my 70 TAs (04b, 05c NOR) the steel plate is threaded with no clip/nut. Wonder if there was a date they changed over, NOR vs. VN, or if it was one or the other supplier.
Old 08-10-2018, 10:26 AM
455hota's Avatar
core support mounting..
https://r.tapatalk.com/shareLink?sha...4&share_type=t
If you view this post, there are two videos which are very informative regarding the core support mounting differences.
...Steve T.
Old 08-10-2018, 11:29 AM
This shows the mounting clips that I have seen ( VN and Norwood) I have NOT seen the longer s clip that Harold has, I wonder if it has the Location "nubs" inside it to keep the "nut" centered in the lower subframe hole.
https://www.youtube.com/watch?v=t9DtbP4ez2A
Old 08-10-2018, 11:31 AM
The actual bolts and mounting
https://www.youtube.com/watch?v=bHJL...ature=youtu.be
Old 08-10-2018, 11:36 AM
This must be two clips, which makes sense. In my video dont have the clip you do which keeps it in place. Probably was pout on the frame in sub assembly
Old 08-10-2018, 05:20 PM
Yes, two clips. They're shown separate in the first pic I posted. (#6)
In the first pic of #10 (and the diagram) you can see how they mate up/slide together.
Old 08-10-2018, 06:35 PM
Thanks Harold, huge help!
