Body support vibration
Attached is a pic of the drivers side rear fender of my GTO on the inside where there's a support in the middle of the pic. What can I use as an adhesive or something to squirt between the bracket and the other skin of the fender to make it stop vibrating.
anti flutter
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Go to any parts store that sells paint & supplies they will have seam sealer. It's the stuff that looks like caulking in a tube that is applied just like caulking. It's used by GM, Ford, Chrysler & all the car makers to fill in spots & level sheet metal in a car for a bbetter look when the body panals. It will cost about $6-8 a tube . Squeeze it out smooth it in place let it dry for about 1 hour & then you can paint or prime right over it . Get in the trunk of your car you have right now & you can see what it looks like by pulling up the trunk mat.
I am aware that they are not the same thing , but never said it was . Seaam sealer is what I would recommend for the use on seams if they seem to be loose & vibrate.
This is what I used for that spot. Very simiar to what was origially there, and a longer working time than the other 3M version.
http://solutions.3m.com/wps/portal/3...glZN846KBPCRbl Note that you need a special gun to dispense it, some body supply stores will loan you one if you buy the material from them.
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
