Old 07-18-2012, 05:43 PM
goatman65's Avatar
Default mig 75/25 gas
Is there any danger in using my mig if the bottle of gas is very warm to the touch?
The temp in my make-shift garage gets into the 90s and at times the bottle is exposed to the sun. Just want to be sure it is safe to use when its that warm.
Old 07-18-2012, 05:55 PM
65blackplate's Avatar
65blackplate 65blackplate is offline
no problem get to work
________________________________________
65 GTO
owner since 84
original ca car
Old 07-19-2012, 04:31 PM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
You are good to go. These bottles sit outside at the fill stations in the sun, rain hail and snow. They are extruded steel and damn near indestructable. Also when gas exits the tank you get a slight cooling effect on the bottle due to the pressure drop.
Old 07-19-2012, 10:06 PM
69Customs's Avatar
69Customs 69Customs is offline
Its a shielding gas non-explosive. No Danger at all.
Old 07-20-2012, 05:58 AM
goatman65's Avatar
Thanks. Just didnt want to blow myself up.
Old 07-20-2012, 07:26 AM
chiphead's Avatar
chiphead chiphead is offline
As others have said, the shielding gas is inert by design IE, not explosive or reactive. It also has a low coefficient of thermal volume expansion, meaning the pressure won't spike really high if the bottle gets kinda hot, like 125F or something.
A nitrous bottle on the other hand, is the type of bottled substance to be careful. As bottle temps exceed 100F, the pressure can really spike due to N20's properties.
