oil filter clearance
I picked up a used set of headers for my 400 in a 69 and after installing them I no longer have clearance for my oil filter (which I had removed before installing) the oil filter is WIX - 51258.
Is this because these headers are not for the 69 Firebird or is there a shorter oil filter I need to use? |
Would the angled filter adapter help to tilt the filter back? I run a Bosch 3423 with long branch manifolds that might help you also.
440, E-heads, Performer RPM, holley sniper, "stump puller" cam, 3.42 gears, 3540 lbs |
You probably need the angled filter mount.
Cholesterol Bad Adrenaline Good Do it till your eyes bug out! |
Never knew there was an angled mount..... Sounds like what I need then. Should be a simple enough fix.
