Old 11-19-2019, 10:36 PM
allenga allenga is offline
Default Red Seat Belt Sleeves
Still searching the world over. Anyone have an old tote with one buried perhaps.
Old 11-26-2019, 03:46 PM
pippintook pippintook is offline
Seems like they might be hard to find. I am thinking likely ebay. An option would to get another color and repaint/redye. I have repainted lots of interior parts on my 78 TA using SEM , like this https://www.summitracing.com/parts/smm-15173/overview/
The Following User Says Thank You to pippintook For This Useful Post:
Old 11-29-2019, 08:09 PM
78 TA KID's Avatar
78 TA KID 78 TA KID is offline
Yeah.. I've been looking for a set of Lt blue seat belt sleeves for a couple of years nothing yet......... Most of them I find are broken.
The Following User Says Thank You to 78 TA KID For This Useful Post:
Old 11-30-2019, 10:33 PM
Hard to get in good condition in any colour. Red and Blue seemed to be chalky before others or cracked. The poor quality repro was a different type again and probably also no longer available.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 01-12-2020, 08:19 PM
Wonder what people are doing instead of using broken sleeves...
Old 01-12-2020, 08:41 PM
Probably anything if the broken area is visible, or the stalk no longer holds the receiver up. To many, an incorrect but intact sleeve is a big improvement over a cracked and chalky faded original and are more than happy. For years mine had a 12" tan set from an A-Body that are mint, until I found a perfect 10" Firebird set, which I then covered in leather anyway. I think most are at the point where you have to recolour them if you find a good set, which also protects the surface from further deterioration.
Old 01-12-2020, 08:57 PM
I would love to see the pictures of how you covered with leather. I will find an upholstery guy..
Old 01-12-2020, 09:28 PM
Obviously, not remotely original or stock looking but neither is my leather interior. The other option was to custom mix some paint to suit the plastic, but decided to cover them instead.
https://flic.kr/p/21zBrWC
https://flic.kr/p/24kzMhr
https://flic.kr/p/24kzMax
Old 01-12-2020, 09:37 PM
Here's another idea if you come across some. This is my 12" A-body set of Deluxe stalks I used for a while with my tan set, shown next to a 10" Firebird sleeve. They worked but the extra height at console was a tad annoying and obv not suitable, luckily they were flexible.
But, if you found a good set in red, or to recover etc, you'll notice that the wiring harness holes in the sleeves are close to 2" higher than the anchor bolt opening. You could easily trim the bottom off, or simply add the shorter Firebird belt inside it and bolt it up through the higher opening, and not see extra length at base, removed or just left in place.
https://flic.kr/p/2ieerHq
https://flic.kr/p/2ieerFM
Old 01-12-2020, 09:44 PM
looks awesome. this is now on my list..
Old 01-13-2020, 09:13 PM
ladytata's Avatar
ladytata ladytata is offline
If interested you can text or call, but please don’t ask me to separate them from sleeve, it’s all or nothing. Teri 8473406638
ID:	528802   Click image for larger version
ID:	528803   Click image for larger version
ID:	528804   Click image for larger version
