Old 11-26-2019, 03:55 AM
dataway's Avatar
dataway dataway is offline
Default Painting over E-coat
I've got a repop core support I need to paint ... is there any problem with paint compatibility? I was planning on scuffing and painting with alkyd enamel. (oil base, similar to something like Rustoleum)
Old 11-26-2019, 07:00 AM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I painted a few parts that were e coated a few years back with rustoleum and had no issues. Has held up fine. I sprayed my e- coated core support with eastwood chassis black however as it's a bit more scratch resistant.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
The Following User Says Thank You to n20ta2 For This Useful Post:
Old 11-26-2019, 08:59 AM
Flynbye's Avatar
Flynbye Flynbye is offline
Default E Coat
You will need to see if it is soluble. Take a rag with lacquer thinner on it and try to rub off the E Coat. If it doesn’t come off, you’re good to go. If it does, you will need to remove it and proceed as you would with new metal to prevent potential future problems.
Some premium sealers do not require scuffing the E Coat, just a thorough cleaning. Doesn’t sound like you are going that direction so scuff away!
The Following User Says Thank You to Flynbye For This Useful Post:
Old 11-26-2019, 12:53 PM
dataway's Avatar
Thanks for the advice folks. I will proceed with the scuffing.
