Old 11-28-2019, 11:41 AM
Gen2guy's Avatar
Gen2guy Gen2guy is offline
Default Shaker scoop rivet/bolt kit???
I'm not a fan of my 77 shaker scoop it sits low on the L78 400 and I don't care for the hard center ridge. I picked up a nice 78 scoop and will shelve the 77 and if I ever sell the car it will go with it. So my question is has anyone used the rivet headed bolts for the flange and also can you see the nuts on the bottom once installed. My rivet gun won't apply the factory style rivets I also see for sale. Thanks
Old 11-28-2019, 12:15 PM
78w72 78w72 is offline
so the 78 scoop is just the fiberglass shell without the metal bottom plate?
as for seeing the nuts on the bottom, if you lower your head low enough you will see them, but for the average person just standing in front/side of the car you shouldnt see them since the scoop sits pretty low.
Old 11-28-2019, 12:23 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I used aluminum lawn chair screws/nuts. They do have a slot on the top but about the same OD and very flat. Bottom piece"nut" is basically a sleeve with a built in flat washer as the "nut". If you want to get real anal on appearance you could put a dab of epoxy on the slot and head.
Skip Fix
Old 11-28-2019, 12:28 PM
burd's Avatar
burd burd is offline
Get a complete shaker.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 11-28-2019, 12:50 PM
Grand73Am Grand73Am is offline
I used the rivet bolts on one of mine, since I wanted to remove and restore the adapter plate. They worked well and look good. You'd never see the nuts unless you remove the shaker to look under it. Put some lock-tite or a little glue on the nuts to keep them from loosening.
8-14-19 - Copy by grand73am, on Flickr
Steve F.
Old 11-28-2019, 06:19 PM
Gen2guy's Avatar
Thanks good to know and the locktite makes good sense'
Old 11-28-2019, 06:22 PM
Gen2guy's Avatar
Thanks for the suggestion Skip
Old 11-28-2019, 06:26 PM
Gen2guy's Avatar
No 78W I picked up a very nice scoop from a 403 car so I'm going to remove the scoop and mount it to my 400 frame. Thanks.
The Following User Says Thank You to Gen2guy For This Useful Post:
Old 11-28-2019, 06:30 PM
Gen2guy's Avatar
I did but it's from a 403 not a 400 thanks burd
Old 11-29-2019, 04:09 PM
Skip Fix's Avatar
I actually used a 77 metal base and omitted the 1/4" plastic spacer between the scoop and metal plate on a 78 scoop so I had and extra 1/4" clearance between the scoop and the hood for a thin carb spacer. And yes that 77 ridge was ufgly!
Skip Fix
Old 11-30-2019, 11:54 AM
Gen2guy's Avatar
Thanks for the info, and I agree
