#41
Old 12-07-2019, 11:25 AM
burd's Avatar
burd burd is offline
Just add a small bottle at the oil change. Then you know what you have in it.
$8 at the swaps.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
  #42
Old 12-07-2019, 11:28 AM
455rebel 455rebel is offline
A problem I've had with 15w 40, not related to wear! Now this is with a amc engine not a Pontiac, but it still applies. Now this usually only happens in cooler weather, but it happens. Last week I was mailing bills and ran out of stamps, looked at time and post office closed in 10 min. I jumped in my car and aggressively drove to the post office. Leaving a stop sign I turned left hard after a roll through and my oil light came on. The oil was cold and thick and had lingered in top of engine , not draining down fast enough, and slid away from the oil pickup. Its happened more than once, on a cold engine. I usually always warm up before aggressive driving, and never a oil light on.
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
  #43
Old 12-07-2019, 04:10 PM
92GTA's Avatar
92GTA 92GTA is offline
I run Redline and use the weight they recommended given my clearances. For me, it's their 10W-40.
During the winter, my car doesn't move after fire-up until the temp gauge does!
1969 Pontiac Firebird
  #44
Old 12-07-2019, 04:46 PM
Tom Vaught's Avatar
Boost Engineer
I have purchased 15W40 High ZDDP oil for many years now and never had an issue with the oil in my 455 engine in the 64 GTO. Course I always put heat into the engine and it was never used as a dual transportation type vehicle like what you describe.
Personally I would say you have it figured out that the thicker oils need a proper warm-up prior to driving them.
I really like that 1350 ZDDP number for the solid lifter camshafts i have run over the many years. $8 for a can of additives each oil change???? I will stick with what I have that I know works for MY application.
Tom V.
  #45
Old 12-07-2019, 07:33 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
VR-1 having high levels of Zinc and Phosphorus doesn't seem like a huge financial stress vs other oils. If you're not a roller cam then running with low zinc and phosphorus is risk I wouldn't be ok with (I only run rollers). Many complained about lobes in cars like ours with the crap 2000s oil due to emissions reductions in those 2 categories.
Engineers suggest the bearings need around a 10 in viscosity. This number is much easier to obtain when you're using....
An OIL COOLER.
Oil cooler with whatever oil or higher Z and Ph and no cooler seem like safer bets. I'm cooler and VR-1, not a big budget killer looking term and now only blows up from my right foot. LOL
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Intake & Rails, PTC 10" 0 Stat, Ricks Hot Rod SS Gas Tank, Magna 4303, Aerom EFI Reg, Aerospace Front & Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, Powersteering.com Pump & 12:1 Box, QA1 Front Arms & Viking Berz CO + Rear Shocks, Hella UP28 Vac Pump
Thread Tools
Display Modes
