Old 12-09-2019, 03:34 PM
mike76 mike76 is offline
Default tightening shifter linkage to my 4 speed
When tightening the linkage to the tranny the 3 arms ( call them pawls) are tightened by 3/8" nuts. If one tightens them the shifter action becomes tight so they need to be on the loose side. In order to prevent the nuts from loosening I'm thinking of putting some blue loctite on the threads. Is that a good idea or is there something I'm missing or doing wrong ? Thanks for the advice, Mike.
Old 12-09-2019, 03:45 PM
Schurkey Schurkey is offline
What trans? What vehicle?
Are the arms and the pieces they attach to in good condition--no bends, no burrs?
Old 12-09-2019, 05:27 PM
Pontiac Performance Author
what shifter/
Old 12-09-2019, 05:52 PM
Stan Weiss's Avatar
Something does not sound like it is setup correctly. Can you post up some pictures.
Stan
Pontiac Pump Gas List
Old 12-09-2019, 06:43 PM
Are these the levers (on the side of the transmission itself) that go on the ends of the shift forks?
Clay
Old 12-09-2019, 07:11 PM
geeteeohguy's Avatar
Normally, these levers are tight enough so that the lock washers used are crushed flat. They need to be TIGHT. If you are having issues with them being tight, something is wrong, possibly inside the cover....if indeed I understand what you are trying to explain. Are the levers hard to move back and forth manually with NO linkage installed? If so, it's a problem with the cover or fasteners.
Jeff
Old 12-09-2019, 07:28 PM
Clay
Yes. ST-10, Hurst comp plus shifter. I have no lock washers on them. Perhaps that is the problem?
Old 12-09-2019, 07:45 PM
Scott Thelander's Avatar
bolt ... lock washer ... washer ... lever ... onto the shifter fork boss
if your shifter gets tight when this bolt is tight
is the lever hitting the side cover ?
the back side of the lever may be beat up ??
Old 12-10-2019, 04:50 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
If your taking about shift arms to shift levers you need new bushings.
Old 12-10-2019, 06:11 PM
STEELCITYFIREBIRD's Avatar
PIctures
Old 12-10-2019, 07:59 PM
I added a lock washer and it freed things up. Went through the shift pattern but is a bit notchy, Mike
Name:	shifter linkage 002.jpg
ID:	526401   Click image for larger version
Name:	shifter linkage 001.jpg
ID:	526402   Click image for larger version
Name:	shifter linkage 005.jpg
Old 12-10-2019, 08:26 PM
nylocks ?
hmmm ... best get the correct washers on the clip side b4 one of those clips pop off ..
I see no washer on 1-2nd ... and the washer is on th linkage side of 3-4 ...
and reverse makes me dizzy
did you adjust the linkage in nuetral now you got it snugged up ?
Old 12-10-2019, 10:18 PM
you make no mention of the bushing. is there one in the shift lever.?
Old 12-10-2019, 11:22 PM
wbnapier wbnapier is offline
Good point, one lever is missing the bushing in the photo. There are plastic ones and steel ones.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 12-10-2019, 11:30 PM
hobbygto65's Avatar
I bought new bushing and clips from 5SPEED, he sells really nice stuff that he's designed.
Old 12-11-2019, 02:08 AM
The pic is a bit deceptive. I assure you the shift levers all have the steel bushings installed. Scott has a good point regarding the thin washers on the clip side. I'll put some AN washers on the 3 levers. Thanks, Mike
