Found this in my oil pan
Can anyone help me identify this part? It's approximately 3/16" in diameter. Looks like a dowel of some type.
I recently screwed up adjusting my valves, a lash cap fell off, and messed up a pushrod. Related to this? I pulled the pan to inspect the oil pump because my oil pressure was 45 psi cold, 10 psi hot at idle. When hot, I rev the engine the oil pressure would rise to 60 psi. Related to this? |
Looks like an alignment pin for your timing cover
Some late model 400's used hollow dowels to line main caps up.
Oil pressure deal sounds like a stuck relief ball in the oil pump. Clay |
^ #2 post
You guys really think a 3/8ths" bolt will go through that 3/16" O.D. dowel?
Asking for a friend Clay |
Here is a pic next to a timing cover alignment dowel.
Sure enough, there were 3 small pieces of Right Stuff in there with the oil pump relief ball.
This is engine has an aftermarket block.
That looks like it could be the cage from a rocker arm needle bearing.
I just found it. It's a broken roller from the timing chain. When the pushrod was damaged, I didn't notice the tip of the pushrod came off. The pushrod tip found its way to the timing chain, broke a roller, and wedged itself into the timing chain. |
The Following User Says Thank You to Mean Green For This Useful Post: | ||
Shhh...Everybody will want one...
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Good catch
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
What brand chain is it?
Well the good thing is it's too big to have gone thru the pump and screwed up the bearings and you found the source of your low oil pressure, so things are not anywhere near as bad as they could be!
Man, you dodged a bullet with that one. That could have been bad! Good thing the oil pressure dropped in this case.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Updated for Pushrod tip wedgie photo-info. Capt. Obvious says
"No business even idling the engine. Timing Cover comes off for Chain R&R." Too bad for having to break TQ on the Balancer, and break coolant. From this armchair view; Low Oil Pressure seems a unrelated concern. |
If I hadn't list oil pressure, I never would have found this. The damaged pushrods happened two weeks and 10 passes ago.
Here's a pic of the damaged pushrods |
I really like one piece pushrods. They are more expensive but I believe the extra cost is justified.
The Following User Says Thank You to 74SDformula For This Useful Post: | ||
Right Stuff to the rescue, and I really mean it this time. That good for nothing sealer may have actually saved your engine. A once in a million chance. I would be buying a lottery ticket!!
What do you think happened to the pushrods?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
