Is POR15 the best thing to paint the underside of [img]/infopop/emoticons/icon_confused.gif[/img] your old wheel wells?
http://www.kurtspontiac.homestead.com/Dannys65GTO.html
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC] http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
POR-15 will really only stick to rusted metal or etched bare metal. If there is any paint in the wheelwells don't use it.
I would use it to coat any rusted areas, then use some rubberized undercoating. Let's go racing! www.outlawpontiacs.com/members/B-Man2.php www.outlawpontiacs.com/members/B-Man.php
1990: I used Epoxy paint (black semi-gloss), spraygunned, and the wheelwells still look excellent. no surfacerust, no delaminations or cracks.
68GTO project will get Epoxy paint, spray gunned, on the firewall, wheelwells, frame, bumper brackets, small stamped metal parts. Half-Inch
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
I like rustoleum then undercoating
can you hear me now? is this thing on? test 1 2 1 2
can you hear me now? is this thing on? test 1 2 1 2 |
come on lee [img]/infopop/emoticons/icon_eek.gif[/img]
"11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
I used a 3M rubberized undercoating inside my wheel wells to fill in the areas that broke off when I removed them. The stuff came in a spray can and had a nossle like WD40. Worked great, builds up fast and clean, can't tell the wells were ever unbolted.
some may scoff...I even did my hood underside and engine compartment and underbody with black statin finish rustoleum spray cans
the undercoating REALLY threw me off.
I imagined the work& results I did on the Fornt fender wells...no undercoat gravel finish. Just semi-gloss black..still smooth and excellent after 12years of street drive. I scraped-off some of the factory rear wheelwell factory gravelcoat, then sprayed cheap primer and paint..still excellent after 12years. So, up to speed now. I see what you mean, and concur. Geez type is easily mis-interpretable. H.I. Stud "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
I.M.O....undercoating is only good for sound deadening & I did use it at the normal places
I just replaced both the inner and outter wheel housings. What is correct? I was going to undercaot but seems to be frowned apon. The inner is bare metal and the outter has the black coating on it.
http://www.68firebird.net |
