Old 03-04-2021, 07:32 AM
er455 er455 is offline
Default BOOST CONTROLLER
What is the best way to control boost with a external waste gate ? I don’t want a c02 bottle ..
Old 03-04-2021, 08:20 AM
charlie66's Avatar
Heres one way . Manual way .. Its what i use . Its works well...
https://www.treadstoneperformance.co...ntroller/c3516
My Half AN Injun.....
Old 03-04-2021, 08:54 AM
taff2's Avatar
taff2 taff2 is offline
If you just want to control your maximum boost then use the 'gates spring to control it- a 12psi spring will give you 12psi of boost. If you use an adjustable ball and spring valve (Grainger type valve) in the boost tube to wastegate diaphram set at 12psi- then boost rise time up to 12 psi will be much, much quicker (the 'gate doesn't 'crack' open until the ball vave opens). 1 psi of boost to 17psi of boost took 0.7 of a second according to my data logs. You can also use a bleed valve on a tee in the boost tube to 'gate diaphram to increase boost level above the 12 psi spring. Basic old skool stuff.
If you want to manipulate boost settings for launch/power control then you'll need an electronic boost controller like an AMS 500/1000/2000
Old 03-04-2021, 09:51 AM
ErikW's Avatar
ErikW ErikW is offline
In lieu of a CO2 bottle, some guys are going to onboard compressed air. Small compressor and tank. No more refilling CO2 bottles.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 03-04-2021, 04:41 PM
Default Boost controller
Thanks guys I have a manual J&S boost controller but I want something like Taff was talking about being about to leave with 5 lbs of boost and ramp up to 15 # ,
Old 03-06-2021, 09:43 PM
70 bird's Avatar
70 bird 70 bird is offline
Use this valve inline with a manual controller and you have 2 stage boost. Spring setting is first then open the valve with a switch to the controller for stage 2. I have been doing this for 5 years now. I run 6psi in first gear and then hit the switch in 2nd for 15
https://www.ebay.com/itm/Electric-Ai...Cclp%3A2334524
Old 03-07-2021, 06:45 PM
krisr's Avatar
krisr krisr is offline
On my daily driver i'm going to use a Turbosmart E-Boost Street controller --> https://www.turbosmart.com/product/e...-street-40psi/
Comes with controller, mac valve and all of the wiring. It has 2 boost settings so my set point 1 will be around 7psi, set point 2 will be around 12psi for when you want all the smiles.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 03-07-2021, 08:17 PM
Hey I have that same setup with a 6 lb waste gate spring so I push the button and just get 6 # of boost and when I release the button I get 1 2 lbs but something happens when it only makes 6# the car spits and sputters like it getting to much fuel for that low of boost or not enough timing as I have the timing locked at 24 degrees .
