Old 08-20-2008, 09:39 AM
Z Code 400 Z Code 400 is offline
Andrew,
I noticed you mounted your ball joint on the bottom of the plate. Was that for more clearance??? Also, looks like you are still using the stock upper control arm attaching studs. Are you using any kind of shims (sleeves) between the studs and the control arms to take up the clearance???
I have the same upper control arms on my 1972 Formula...Robert
  #182
Old 08-20-2008, 12:10 PM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Originally Posted by Z Code 400 View Post
Andrew,
I put the ball joint on the bottom because that makes the spindle seem a little taller. The instructions said either way is acceptable.
I am not using any sleeves, but I probably should.
Andrew
  #183
Old 08-22-2008, 04:57 PM
andrewb70's Avatar
I measured the distance from the ground to the headers and right now it is 5". While the car would look a little better lowered, I think it is important to keep the car as practical as possible, without the danger of hurting parts. So for now, it will stay where it is.
Today I did a little project that I have been neglecting to do. Many of you have asked me what I am doing to retain the axle in rebound. To recap, I am using short 9.5" springs in the rear. The problem is that when the axle drops, the springs get unloaded. This is not a good situation. And while the odds of getting the car air borne are fairly slim, if it were to happen it might be catastrophic. The other issue is that the single pigtail springs do not seat really well in the upper spring pocket.
I picked these up on eBay for $20 shipped:
They are rubber spring isolators from a 4th gen F-body. They fit the single pigtail springs perfectly:
The rubber spring isolators fit perfectly into the upper spring pocket on the a-bodies.
Here is what I did to keep the axle from dropping too far. I took a 2" nylon axle strap. It used these to loop over the rear axle when I was towing the car. At the top I attached one end to the T-bar of the upper shock mount:
At the bottom I looped the loop around the shock mount stud:
When the axle drops and hangs by the straps, the springs are still compressed about 1". This will keep them safely in place in case I want to do some Dukes of Hazzard maneuvers. :screwy:
Andrew
  #184
Old 08-24-2008, 04:55 PM
andrewb70's Avatar
Yesterday I took the car to get the corner weight set and to make sure that my front sway bar was installed in such a way that it was not pre-loading the suspension. I took my car to Nashville, to Earl Owens Chassis. If anyone in that area needs any kind of fabrication or setup help, Earl knows his stuff.
Here are the new corner weights:
--LF------------------RF
1094-----------------1044
--LR-----------------RR
968-----------------913
This is with driver of similar weight to me.
Total: 4019 lbs
Distribution: 53.2 Front / 46.8% rear
Cross weight 50%
This was done with the front sway bar disconnected. Minor adjustments were needed on the drivers side rear spring jack to get the cross weight to 50%. Once the weights were adjusted I installed the sway bar in such a way that it did not alter any of the corner weights. I know that the sway bar was preloading the suspension fairly heavily before. This was evident by the fact that when I made right turns, the car would handle very neutral. There was just a hint of understeer that was easily controlled with the throttle. When making left turns the car would push much harder and the understeer was less controllable with the throttle.
Now the car handles the same way whether I am making left or right turns.
After installing the AFX spindles, I had to get the car aligned again. I decided to add just a hair more negative camber.
-.7* camber
5.5* caster ( little more on the right)
0 toe
The handling is very neutral. There is just a hint of understeer that is easily modulated with the throttle. The biggest difference is going over bumps, especially when just one wheel hits a bump. Before, the car would dart and wander. I have no doubt that this was cause by the bump steer due to the b-body spindle swap. With the AFX spindles all of that is gone. The car tracks straight as an arrow when going over bumps. There is a slight tendency to track along the grooves in the road, but I attribute that to the shorter sidewall on the new tires.
Andrew
  #185
Old 09-02-2008, 11:47 PM
andrewb70's Avatar
Tonight I decided to take the car to the drag strip to see how my new tires worked. I got to the track, did my burn out. The car pulled hard out of the hole. I was able to launch it from about 3000 RPM, slipping the clutch a little, no tire spin. On the 1-2 shift, it felt like I missed second. No big deal. I aborted the run. Stepped on the clutch and got nothing. No pressure at all. Straight to the floor. I matched the RPM and got the car into 3rd gear and drove back to the pits. Looked under the car and saw a nice little stream of fluid coming from the bellhousing. So the hydraulic TOB puked.
I now have less than 9 days until RTTH IV. I need to order a rebuild kit. I may even order a new TOB. I am not looking forward to spending the weekend on my back, but it's better that this happened now and now a week from now.
Andrew
  #186
Old 09-05-2008, 03:37 PM
andrewb70's Avatar
No mystery here:
Based on the cut in the o-ring the problem was over traveling the bearing. I guess the excitement of drag racing made me press on the clutch pedal just a little bit more than when I drive around town. I will do some more investigating and see if I can limit the movement of the pedal and still get enough travel at the bearing to release the clutch.
Stay tuned for more.
Andrew
  #187
Old 09-05-2008, 07:24 PM
andrewb70's Avatar
All fixed. It's raining so no test drive but I am sure its fine. I shortened the rod that connects the pedal to the MC. This reduced the stroke of the MC thus reducing the stroke of the TOB. I was still able to turn the output shaft easily by hand when the clutch was pressed. So I was definitely overtraveling the TOB before. Back on track for RTTH IV!
Andrew
  #188
Old 09-18-2008, 11:37 AM
andrewb70's Avatar
Here is a link to some pictures from last weekend's Run Through The Hills IV event. Good times!
Run Through the Hills pictures
Andrew
  #189
Old 10-05-2008, 01:53 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
That looks like a blast! Some nice rides there. Were those all your pics?
Mike
  #190
Old 10-05-2008, 11:52 AM
andrewb70's Avatar
It was definitely a blast, Mike. All of those pictures were taken by my friend, Tony.
Andrew
  #191
Old 11-02-2008, 09:16 PM
andrewb70's Avatar
I took the car to the track this Saturday. The weather was awesome. Clear skies, dry, and high 60s. I only made 3 passes because my time was limited and there were a ton of people at the track. All passes were made without fooling around with tire pressure or shock settings. Drove it right off the street, into the staging lanes. My first pass netted the best MPH to date; 112.31 MPH. The second pass netted a my best ET to date:
60' 2.064
1/4 12.602
MPH 110.97
This is my last trip to the track for this year and I am very pleased.
Andrew
  #192
Old 11-23-2008, 10:47 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
Totally Ingenious build and results. Thanks for sharing it all.
Josh
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
  #193
Old 11-26-2008, 10:59 AM
andrewb70's Avatar
Josh
Thanks Josh.
The pictures are fixed. Sorry for the troubles.
Andrew
  #194
Old 12-20-2008, 02:26 PM
andrewb70's Avatar
Here is a video clip that was made by Brian Finch. Thanks Brian!
RTTH Video
Please right click and save to your local drive.
Andrew
  #195
Old 12-20-2008, 07:01 PM
andrewb70's Avatar
Here is another video that was put together by Kevin Oeste from V8 TV. Thanks Kevin!
V8 TV Video
Andrew
  #196
Old 12-21-2008, 12:15 AM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
Good bit of driving there
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #197
Old 01-01-2009, 11:11 PM
andrewb70's Avatar
Thanks! I did OK. By the time I figured out what I was doing, I was done with my runs. :-/
Andrew
  #198
Old 04-10-2009, 05:27 PM
andrewb70's Avatar
I really haven't had much to report up until now. Yesterday I was looking around on www.chevelles.com, a member posted that he just had his Doug Nash 4+1 converted to dog-ring engagement by Liberty. This got me thinking. The old Doug Nash is very similar to my Richmond 6 spd. I have never been very pleased with the way my transmission shifts. I have dealt with Liberty before on a dog-rign T56 transmission for my RX7, and I was very pleased with the results. So after talking it over with Paul, I decided to get my Richmond done. Gears 1-4 will get faceplated and 5th and 6th will remain synchronized. No need to have dog-rings on cruising gears. Total price will be about $800. I am pretty excited!
Andrew
  #199
Old 05-16-2009, 09:12 PM
fbrown fbrown is offline
I'm having trouble finding a PS hose for my 68 Lemans/LS3 conversion. What did you use in yours?
  #200
Old 05-17-2009, 10:12 PM
andrewb70's Avatar
I converted the fittings in the steering box and in the power steering pump to AN style fittings. Then I had custom hose made at my local, industrial hose supplier.
Andrew
