View Poll Results: What would you use on a all stock car that is rarely driven?
Points 25 39.06%
Pertronix 18 28.13%
HEI 21 32.81%
Voters: 64. You may not vote on this poll
Old 09-25-2017, 06:12 PM
LeMark LeMark is offline
Default Points, pertronix, or HEI?
Sorry if this post has been hashed to death. I just got my dream car, a 1970 Lemans with a 400, and I'm trying to decide if I should leave the ignition system alone (stock), going with a pertronix system under the stock cap, or a HEI.
I would go HEI, but I was concerned about the larger cap and coil fitting under the Dual snorkel air cleaner. Is that a problem anyone has experienced?
I'm only going to be driving the car a few hundred miles a year, so I'm tempted to just leave the points intact and check the gap every few years. But It seems all the advice I'm getting is to dump the points.
I'd like to hear some fresh opinions and advice
Old 09-25-2017, 07:06 PM
marxjunk marxjunk is offline
points...dead reliable need maintenance...on the side of the road, you can probably get home with just a touch of work..yearly check up mandatory...uses a resister wire out of the fuse block...they have issues with age
buy genuine a/c delco, old borg warner, or MSD stuff...buy stuff for a 69 Z28... better stuff
hei..dead reliable..good to 5000-ish rpms..when i dies..its dead...a little work on most air cleaners needed..need 12 volts all the time..so you have to run a wire out of your fuse block
buy DUI stuff....cheap and reliable...a/c delco cap is about 75 bux now...crazy...
pertronix...people rave about them..never used one..never intend to....but when dead..its dead...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 09-25-2017, 07:57 PM
Thanks for the input. I was leaning toward keeping what I have assuming it's in working condition.
I have a bogging problem at the moment. If the carb doesn't wind up being the problem, I'll look at the Dizzy next
Old 09-25-2017, 08:08 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
HEI is my favorite. It is a proven reliable way to upgrade your ignition. No problem with the dual snorkel on my '70
Old 09-25-2017, 08:38 PM
this one?
https://www.summitracing.com/tx/part...w/make/pontiac
Old 09-25-2017, 09:14 PM
carbking's Avatar
carbking carbking is offline
Points - 'nuff said!
Jon
Old 09-25-2017, 09:19 PM
MUSLCAH MUSLCAH is offline
Iam having Cliff set up my stock Distributor ...the HEI that is currently in it ...is coming out. Going back to points. Just couldn't get that aftermarket Distributor to do ..what it needs to do.
Old 09-25-2017, 09:44 PM
F ROCK's Avatar
F ROCK F ROCK is offline
points.
I have changed my share of hei modules on the roadside.
I once had an ACCEL points eliminator in there and I guess it worked ok but I didn't trust it; and went back to points.
Gotta buy a few sets to get one good set but that one good set will last for years.
Gotta buy the ones with the separate condenser.
you can usually make it home with points.
Just my opinion.
Old 09-25-2017, 09:56 PM
if you are talking to me, which i think you are..
no dont buy that DUI distrib..get a used hei and put the DUI cap kit on it...
i feel for a stock type driver..points is the way to go..just buy quality stuff..good quality stuff.....like old stock borg warner stuff..its cheap and high end..
Mark..
The Goat whisperer
Old 09-25-2017, 11:19 PM
66beaumont's Avatar
66beaumont 66beaumont is offline
Petronix. Had this in my 66 Beaumont for 5 years,no problem whatsoever and kept points in glovebox in case of emergency. Just converted the goat to petronix two weeks ago, I like the no maintenance aspect
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 09-25-2017, 11:25 PM
tom s tom s is offline
Have pertronix in 3 cars,started using them like 20 years ago with no issue.All have been installed and setup by professional dist people.Last one was Suntuned on this forum.Tom
Old 09-25-2017, 11:27 PM
I use a stock small body factory dizzy with the pertronix kit.Not their dist.Tom
Old 09-26-2017, 12:21 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
1971 TA factory distributor with pertronix in it. It seemed to run better and haven't touched it in 15 years. Still running 7 volt wire.
Old 09-26-2017, 08:05 AM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
Default Lectric Limited Inc.
Lectric Limited, as far as I am concerned, the best, most OEM looking Breakerless Ignition on the market. I have their ignition on both my 1968 Camaro and also the 1971 LeMans Sport
May want to give them a call...
https://www.lectriclimited.com/conve...nversion-85052
ID:	464222   Click image for larger version
ID:	464223   Click image for larger version
ID:	464224   Click image for larger version
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
Old 09-26-2017, 11:12 AM
that does look interesting, and easy!
Old 09-26-2017, 12:49 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
One thing to keep in mind with any version of a modern electronic distributor or transistorized ignition conversion kit is if you have a factory tach that has just one wire from the back of the tach to the "-" side of the coil, the modern ignition upgrade will disable your tachometer. The signal from the conversion kit is different than the pure square wave of the opening and closing of a set of points.
If you want your tach to work: The tachometer will need the circuit board replaced as well as an additional wire added that runs from the back of the tach over to the fuse block. The new wire gives the tach 12 volts of "+" battery power whenever the key is in the on or run position, which is used to power the tach. I am sure that the makers of these ignition system(s) are fully aware of this but it is something that you never see in their advertising.
Peter Serio
Owner, Precision Pontiac
Old 09-26-2017, 05:31 PM
Kurt L71S's Avatar
And their Tech Support is great as well...They can accommodate the in dash tachs too.
Old 09-26-2017, 06:03 PM
seriously? it will work with a stock in dash tach? That's a huge plus!
I"m calling them
Old 09-26-2017, 09:17 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
My Pertronix 2 just failed after three months. Really disappointed, and I emailed them Friday and haven't heard back from them.
Mitch Kunath
Old 09-29-2017, 11:49 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Did you use to Flame thrower II coil. I have heard you can't mix the original flame thrower coil and #2 together. I have mine for the last 4 years and the only I hate is I had to run a 20 degree limiter in mine It was throwing 28 degrees in to the total timing. With 12 degree initial, it was giving me 40 degrees total timing.
