I am switching to electronic distributor, but first, I get 6 volts at coil when ignition on, 12 volts when cranking, then 6 volts again when running. Is this right?, and if so, do I need 12 volts constant for electronic dizzy and where do I get it from? Thanks Frank.
You will need 12 volts all the time.
The 12 volts while cranking is coming from the wire to the solenoid on the starter.You can keep that if you want. The wire from the firewall to the coil has to be replaced.The original is a resistor wire. You can run a separate wire to the coil,bypassing the original.Just disconnect it. johnta1 Pontiac Power RULES !!! www.wallaceracing.com
Thank you John for your reply. My car was converted to right hand drive in the early 80s, so under dash is very messy with extended wires etc. So where does the resistor wire start from & what colour is it? Thanks Frank.
The wire usually starts on the engine compartment side of the firewall connector.
Not sure of the color off hand,think it's black with white stripe? It should be the wire that goes from the coil towards the firewall. johnta1 Pontiac Power RULES !!! www.wallaceracing.com
Hello Franky 455,
I'm also a T/A owner in Sydney. Have you seen the club site at - http://www.camaro-firebird.org/ Lots of local Aussie F-body owners and info. All the best with your 74 project. Regards, Leigh 1976 Trans Am 1970 RS/SS Camaro Sydney, Australia
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
G'day Leigh,
I am actually a member of the original Camaro Firebird Club and was the president for 7 years, before retiring. Our club is called the Camaro Firebird Owners Club of Australia Inc. and was established in 1987. Here's a link to our site: www.CamaroFirebirdOwnersAust.com.au We host the monthly All American Mystery Cruise Nights, which you may have heard about. Next cruise is on Sat 8th Nov. 7.00pm Parramatta Pool carpark. We get up to 80 American cars and would love to see you there. My car is the black '74 Formula with the Simmons, come and say hi. take it easy, Frank |
Frank:
The resistor wire starts at the bulkhead connector at the dash panel. It is black and is labeled it's entire length as resistor wire. I converted my 74 SD-455 car to a Unilite module in the distributor which requires 12V constant. I disconnected the bulkhead connector and unterminated the resistor wire for the insulator. I replaced it with a new black wire of the same gauge with a new terminal on each end. Plugged everything back together and put it all back into the convolute. You cannot even tell any work was done. This may seem excessive to some people, but to me, it makes the job look perfect.
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
