I'm assuming you put high pressure cool water into the heads at the centre exhaust valve area via a tube and fitting?
I like the dry decking myself, no chance of water in the cylinders. Reverse cooling, well,it makes sense, cool water to the hot heads first, warmed water onwards to the cylinders. Much better for detonation resistance too,cooler heads. But each to their own. |
Dragncar, yes I think there would be a benefit, LS engines are reverse cooled, one of the reasons they could run a higher compression on pump fuel.
Has anybody else noticed the oil between the layers of a cometic gasket upon disassembly that hasn't been sprayed with cooper coat ? I think it probably migrates from heads following hd studs .
505 CID, 3560 lbs,Tiger heads, NA. 8.99@149.8 mph, 1.29 60', stock suspension |
I'm sure its wizbang with years of R&D... I say that in all seriousness...not actually being a smartass |
Computer Simulation 60 Foot ET = 1.0210 330 Foot ET = 2.8820 1/8 Mile ET = 4.4463 1/8 Mile MPH = 157.3389 1000 Foot ET = 5.7998 1/4 Mile ET = 6.9531 1/4 Mile MPH = 195.3238 Stan
Mark,
Great technical response! Stan
The Following 2 Users Say Thank You to Stan Weiss For This Useful Post: | ||
Water pressure in my dry deck/reverse cooled combo is controlled by using smaller diameter outlets at the block exits in the traditional manner. 55gpm electric pump. I've never seen a need to monitor water pressure via my Innovate (much cheaper than your Racepak) datalogger. Of course I just have a little 420 with factory heads and block, yours is much bigger. You can't get cooler water to the heads than using it directly from the radiator,before it gets heated by the cylinders. Unless you pump it from a cold water tank. Internal water pressure may be an issue in your combo due to local hotspots, I don't know. Have you ever used a dry deck/reverse cooled setup on your combo? Mike, I had the oil migration on my solid copper head gaskets because I didn't spray them with a sealer, lesson learnt. |
Explain this one. I gave my opinion to the OP and you started in with me like you do with everyone here. My facts are my facts .. No need the tell me i have no clue about what i know. YOU KNOW NOTHING ABOUT ME!
Next time pass on by my post . Your just a bully and i dont like bullys... Like i said last time. Have a great day...
My Half AN Injun..... |
The Following 2 Users Say Thank You to charlie66 For This Useful Post: | ||
