It's from a car in a junkyard. What is the engine and where did you find the code for it? The VIN appears to read: 2W87Z6N5573XX. This is the second VIN I've found using online decoders that doesn't indicate what engine it is.
Thanks. Doug ----------------------------- [This message was edited by PonchoV8] www.geocities.com/yqtnxnb |
2W87Z6N5573XX
2 = pontiac divsion W = Trans Am (75 - 80) 87 = Body type number: Sport Coupe Z = Engine code: 400 c.i.d, 4-bbl V8 (1977 - 79) 6 = Last digit of model year: 1976 N = Assembly plant location: Norwood, Ohio 5573XX = production number Hope this will anser your quetsion. Owner of a 1974 Formula 400 in Ängelholm, Sweden!
Owner of a 1974 Formula 400 in Angelholm, (70 km north of Malmo) Sweden! |
So it's okay that it's a 76 VIN and the Z is a 77-79 engine code? Okay.
The 400 "Z" code was also used in '76. Rocky probably knows more.
So long, farewell. |
1976 did use "Z" in the VIN for 400. I've not seen any other letter in all the VIN's I have collected.
Scott's VIN decoder tells me it's not valid is why I was curious. Thanks all.
http://www.pontiacs.org/modules.php?...57395&name=vin Doug ----------------------------- [This message was edited by PonchoV8] www.geocities.com/yqtnxnb |
'Z' should be for the 400 in 1976.
'W' would be for the 455 in 1976. johnta1 Pontiac Power RULES !!! www.wallaceracing.com
