Old 11-18-2003, 07:30 AM
bj1160 bj1160 is offline
will a 77 T/A interior fit in a 74 T/A?
Old 11-18-2003, 10:59 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Won't look the same but otherwise, Yup.
1971 Trans Am 455 HO - Cameo white
1973 Trans Am 455 - Buccaneer red
1984 Trans Am 305 - Royal blue
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 11-18-2003, 12:35 PM
FURBIRD's Avatar
FURBIRD FURBIRD is offline
There are going to be 2 problem areas. The most obvious is the rear windows, 74 in flat, 77 is wrap-around style, so the interior trim pieces will be different. Other problem is going to be on the door panels. The sheet metal on the doors is stamped different because of the different styles of pull handles. You can get around this by rivoting a portion of sheet metal with the correct contour from a 77 door onto your 74 door.
I used 77 doors on my 74, kinda the opposite of what you are doing.
