Old 07-21-2002, 09:34 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I got some new in the GM box T top gaskets from a supplier and was very unimpressed. They are taller that the recess for the T top in the roof when laid in, hard to even get the T top to engage.
The corners that are molded are much shorter there. Old one corners were alot closer in height. The molded areas material also feels like it has silicone grease on it even after detergent bath and lacquer thinner wipe down.
The entire gasket feels harder than the old ones I took off. Anyone used Metros? their door gaskets feel soft enough.
Skip Fix
Skip Fix's Avatar
Skip Fix
