Old 03-16-2015, 08:06 PM
cnc's Avatar
cnc cnc is offline
Default Wiper motor
Ok trying to help out a fellow PY'R
He was looking for a wiper motor for his 73 ,,,I had a wiper that I wasn't using from my 73 I had replaced mine due to leaking pump housing...
His is the first pic mine is the second ...why the difference in position of the 3 terminals
When I replaced my wiper unit it was a direct replacement...all terminals the same spots....
His is upper right mine is lower right........chime in guys whats the diff....???
When I replaced my wiper unit it was a direct replacement...all terminals the same spots....????
ID:	392948   Click image for larger version
Name:	2015-02-16 19.21.07.jpg
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 03-16-2015, 11:23 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
The one on the right is correct for a 70-73 firebird with park feature.
The one on the left is a later model.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 03-17-2015, 04:32 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=771276
Need answers.
Did the '70-early '73 use the 8790844 (stamped on mylar foil tag) motor? And, later '73-up use the 9691870, or was later '73 a one hit wonder?
