61-62 B-body fan shroud.
I'm in the market for one and ran across one for $500. Does that seem excessive or am I just that out of touch on these things.
i dunno...the big car shrouds are way /or where...easier to buy than GTO shrouds..and part of the problem for scarcity is, they convert them to GTO so its killed half of them right there...
i sold a 63 ruff one on ebay for like $350...so a mint one is prob worth it..id say look around a little more, you may fond one, or you may search for 3 years... they are tuff to get in 2019 all that 61 62 stuff is hard to find....
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
Does sound excessive although they are hard to find. Don't remember what I paid for mine but that was several years ago. Certainly not $500. And I compromised on a 63-64 shroud. They can be made to work by adding a flat piece of steel to either side so the mounting holes can be moved out 1 inch each side. If you are judging for points that would be unacceptable. But it works and likely no one but yourself will ever notice.
IMO very excessive that is a $100-$150 item.
fan shroud
i will take two at 100 each let me know thanks
The Following User Says Thank You to 62 bv For This Useful Post: | ||
The trick is trying to find one...they were used on a/c cars only (as well as some cars with heavy duty cooling, like police cars) and since air conditioning was a pretty uncommon option back then there just weren't that many of them made.
Watch ebay and craigslist religiously.
And then try to get the correct finger guard also. Proper ones have a little bracket that bolts to the shroud. Some are long and some are short. Not sure what is correct for each year.
short one
I gave $300 for this one , NOT FOR SALE!
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon! |
Here's a '63/'64 on ebay no buyer so far with 8 hrs left to go. Listed @ $199 with a "make offer" option. Make the man an offer.
https://www.ebay.com/itm/63-64-Ponti...53.m1438.l2649 |
But I am running a 19 inch blade. I have an 18 inch left from some old Chevy years ago but didn't use it because of the diameter. The 19 inch has about 1 inch space to the shroud all around and if I don't break a motor mount and torque over too far I think I' good. The blade I'm using came off e-bay and is one of those originally (I think) for some model option for 65 GTO that has the little notch at the end of each blade. |
