New (to me) Truck...
So my mom & dad downsized and dad ended up getting rid of his truck. I offered to take it off his hands for a nice price. Its a 2001 Ford F-250 with the 7.3 and 101k miles. He bought it 8.5 years ago and put less than 10,000 miles on it. Any surprises or gotchas I should be aware of in this year of truck? Or even just basic maintenance it will need at this era of its life? Dad says he did nothing to it other than oil changes and 2 new batteries. I drove it 1200 miles home pulling a trailer and it did great.
You are a lucky man! With regular fluid changes that thing should last you a lifetime. Any later 7.3 with that low mileage is worth a premium. Is the body (rust free) solid and straight?
2001 was one of the best year ford trucks ever built. I had a dually 4 x 4 that I put 130k on it and never had one repair done to it. the repair at 130k was putting front brakes on it. but considering I pulled a 42' trailer behind it daily you cant complain about that.
Thedieselstop.com is a website a friend has relied on for a lot of info. He has a 99 F250 4X4.
There's specifics about virtually every year that are different. Just the fact that you have a 7.3 is the best thing. He has one of the programmers hooked to his, helped with power and MPG. I installed same brand programmer on a church bus. My crs is acting up, will have to give you the brand later...Lol He has had to change the front hub bearings at least twice, of course it's a 4X4, and has close to 300,000 miles on it now...
I think you scored a pretty good deal. Then again im a ford guy. That truck isn't even broke in yet. You should be able to get at least 250k miles before its gonna need anything (other than routine oil change every 5k). Ive got almost 300k on my f 150 gas model and its a lightweight compared to yours!
I had the identical truck. Drove it to 286,000 miles and would still have it if it did not need a frame-off restoration and a cab due to rot. It is well known in the light duty diesel world that there are only 2 good diesels, the Cummins and the 7.3L.
Common issues? There are a few. Oil pan rots out Wire harness in the valve covers goes bad Glow plugs Glow plug relay (Especially if you don't replace a Ford or International relay) Occasionally an injector Must periodically change axle lube and only use the Ford additive Depending on miles per year, annual oil changes are a must to achieve optimum fuel economy Add diesel additive once a month - I ran Power Service Diesel Kleen Run "off-road" diesel every chance you get Change fuel filter once a year That is all I can think of at this time, they are rather maintenance free engines. Now the brake system is another story. Expect to free-up calipers often. Both pistons and sliders. |
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
Make sure you fill the oil filter too when you change oil. It won't start afterward without a whole lot of cranking if you don't. That filter holds 2 quarts.
"I know just enough to keep me here, but not enough to get me out" |
Have 2001 F350 dually , 7.3 automatic that I bought 4 years ago for $3000 with 324,000 miles, has 340,000 miles now. Things I've done are IPR, front calipers, starter and all battery cables and starter relay.
Eric 1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60' 1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85 |
Biggest issue with these was the cam position sensor. Easy to change if it goes out.
Throw a load of injector cleaner in it and put some miles on it. We used to use 1qt of Power Service Systems (silver bottle) and one quart of type F transmission fluid. Run a good oil like Shell Rotella 15/40 or Chevron Delo 400.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
Almost 300,000 and never needed to do a cam sensor or injector and changed the fuel filter once in a blue moon. I even totalled a Nissan Altima with it and all that happen to my truck was a small crack in the grille and, as you can see, the front bumper got slightly bent.
Nice looking truck Chief
Thanks! That was the last time I had it touched up due to rust & rot. Those rear flares are hiding quite a bit. But that truck took me and my hot rod to many tracks up and down the east coast.
Thanks all. It's a West Texas truck, so no rust whatsoever. 8 foot bed extended cab 2WD. It's simple enough compared to cars from the last 4-5 years yet overall modern at the same time. Much more modern than my old 6.2 diesel engines - and it starts after one cycle of the key in 25F weather without a block heater.
Brakes still being sticky doesn't surprise me, my old '95 F250 went through calipers and hoses regularly and cooked the rotors if I wasn't careful. |
Those 7.3 Powerstrokes are some of the best diesel engines to ever roam the earth. Super reliable, parts are fairly cheap, and no emission crap to deal with.
Getting one with such low miles is rare!
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
In my spare time, I like to back my 7.3 up to a Starbucks outside patio and let it idle for about 30mins or so.... great engine...
Also keep the coolant changed, neglected cooling maintenance causes calvitation with 6.9 & 7.3s.
Two 1975 455 Grandvilles & '79 455 Trans Am 69 Camaro SS 396/375 (owned since 88) 22 Toyota Sequoia V8 23 Lexus LS500 awd 95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
Must use Motorcraft coolant additve FW-16 for the cavitation. See owners manual. You add a bottle at coolant change, and 8 oz every so often. It is in the owners manual.
I've had my '99 7.3 for about 5 years now. Only thing I've had to do is change the injector harness under both valve covers. I also upgraded to a newer style factory Ford air intake /filter system for better filtration. Mine's a 2wd with the 6 speed manual. I'm in the rust belt, so I bought it out of Mississippi so rust free. Plan to drive this thing forever since it's only got 170,000 miles on it.
The crank sensor is a common problem, so I carry a spare in the glove box in case I ever need to change it along the road.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week 14, 15, 17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
I always used CAT coolant only because I bought a bunch in bulk at an equipment auction.
