Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-12-2016, 11:53 AM
MiamiHenri MiamiHenri is offline
Default 7F6 Round Port HO heads stock take offs
Have had these gems for over 15 years bagged and stored away. Virgin take offs, no milling, porting or surfacing. No pitting in the chambers as you can see, stock valves and hardware in great shape. Matching ate codes "I241" September 24, 1971
Great for a restoration car.
Asking $3400 open to offers, no trades. They are on eBay as well #112232112192
Thanks for looking, Henri...
Name:	pontiac heads 077.jpg
Old 12-14-2016, 08:27 PM
Price drop to $2850 !!! Looking to sell these before the end of the year. Feel free to ask me any questions. Thanks Henri...
Old 12-14-2016, 08:38 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
In the picture of the intake port it looks like the center divider is rusted/pitted and recessed so there wouldn't be a good seal between ports. Is that what I am seeing?
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
Old 12-14-2016, 09:04 PM
Default Intake ports
No rust at all, that's the way these are made. The intake ports have that recess cast from the factory. Thanks for looking...
Old 12-14-2016, 09:05 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That is a scallop you see on the intake port common wall. They were put there by the factory, no one seems to know why. Most of the original service heads were cast that way.
Go fast, see Elvis!
Old 12-15-2016, 12:11 AM
marks73ta's Avatar
marks73ta marks73ta is offline
I bought a new '72 TA and I continued to have a problem with the gasket breaking out of the center between the ports. GM would only replace the gaskets, which they did under warrantee 3 times. I finally glued extra gasket material to the center of the gasket to take up the missing cast iron. I planned to mill the heads as my next solution, milling the decks and then the port gasket face but never got that far. Like was said, no one can come up with a reason for why they did this. The '71 HO heads did not have this problem?????
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 12-22-2016, 11:17 AM
Last price drop $2200 then back in storage.
I was saving these heads to use in a boosted set up since they have some advantages such as large cc chambers and the center ports not melting. Also the ability to hang a heavy turbo on them. Member 455Turbo went high 9s with these same heads in a heavy 2nd gen bird street car 10 years ago. If doing a turbo set up you might look into these. Thanks for looking and have a Merry Christmas, Henri...
1968 Convertible Lemans running driving work in progress.
