Old 05-01-2017, 01:48 PM
pggto's Avatar
pggto pggto is offline
Default Distributorless Ignition System
I was kicking around the idea of using a dirtributorless ignition system on my 70 GTO. Does anybody have any experience or recommendations? What systems have you used? Where did you mount it? Thanks
Old 05-01-2017, 04:15 PM
Bill Hanlon's Avatar
What is going to spin the oil pump?
Old 05-01-2017, 04:34 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Search EFI in the Boosted forum on PY, good info there.
Old 05-01-2017, 08:21 PM
A distributor housing, without a cap on it. ; ) I'm sure you will need to fashion one unless someone already makes one.
Bill Nye.
Old 05-01-2017, 10:28 PM
marks73ta's Avatar
marks73ta marks73ta is offline
BOP makes an oil pump drive "stub" to run the pump without a distributor. You can order it with any type of gear you need. I built my own front drive distributor run off the cam gear using a MOON front cover but never ran it. I went distributorless using a Megasquirt MS3 and coil on plug. I still used a modified chevy cam sensor in place of the front distributor.
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 05-03-2017, 02:23 PM
wim firebird's Avatar
wim firebird wim firebird is offline
Default ....
https://www.autosportlabs.com/product/megajolte/
https://motorsport-electronics.co.uk...nodiz-pro.html
Old 05-03-2017, 08:45 PM
antique69lemans antique69lemans is offline
I use this on big block ford. Coil packs off 4.6 crown Vic or mustang. It is waste spark so only need crank sensor.
Old 05-03-2017, 10:25 PM
Tom Vaught's Avatar
Boost Engineer
Luhn Performance did a CNP System (coil near plug) using individual coils on John Cleggs
engine (Pontiac Racer out of Texas and I believe he also did a system for Kelvin Poe in Kansas for his Holley System. Mark at Luhn Performance owned BOP Engineering before he sold it to the current owner "Wade".
So he knows all about the stuff you need to do on the distributor spud and the oil pump drive.
Kind of "Busy" on the valve cover but works well on modern vehicles.
The Luhn deal comes off the valve cover and swings out of the way for valvetrain maint.
Tom V.
Old 05-04-2017, 06:52 AM
mgarblik mgarblik is offline
BOP makes a nice billet stub drive for the oil pump. If you decide to go this route, I have a new one with bronze gear for sale. PM me if interested.
Old 05-04-2017, 10:02 AM
HWYSTR455's Avatar
There's a couple dual and quad post coil packs on the market, and if you have room, you can hang them off the back of the head.
There's multiple options for triggers and pump drives, and yes, the boosted section is a good source of info.
There are stand-alone controllers for DIS, but honestly, if you're going to spend the money, you would be better off in the long run using a 'main-stream' EFI ECU, for reliability and support.
ID:	453780   Click image for larger version
ID:	453781   Click image for larger version
