Old 11-21-2020, 11:44 PM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Default Box 25
I was looking over the build sheet on my 72 Lemans and noticed box 25 “spec order”. Does anyone know what this box is? Did a search with no luck.. Thx
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 11-22-2020, 07:31 AM
johnta1 johnta1 is online now
Can you post a scan of the build sheet?
I think on at least Fremont build sheets the box 25 was for the color of the car.
Possibly a special paint car.
If so, it may have the paint formula/color on it down lower on the sheet?
Old 11-22-2020, 10:12 PM
Holeshot71's Avatar
This is a Framingham built car. The color is Lucerne Blue, not sure if it’s a special paint color? I checked the build sheet on my 71 GTO and the box is empty, same with a couple others that I came across??
Old 11-22-2020, 10:20 PM
I kind of mis-spoke on the box 25.
I think if the car has a special color, it would be noted in that box 25.
But it seems a lot of different things were noted in there if it had some special option. I don't know what they mean other than the special color one.
Your car does not have a special color. And if it doesn't note anything there, it doesn't have a special option.
I found some buildsheets I have that show a 451 among others.
Not sure what that pertained to. UPC 451 was wheel disc, which didn't apply to that buildsheet. (Had Rally wheels)
Old 11-23-2020, 09:16 AM
Holeshot71's Avatar
The code in the box is 22CGY V
Also there's a hand written “289” at the bottom of the sheet if that means anything?
Old 11-23-2020, 09:39 AM
Can you post a pic of the build sheet?
DO you have the PHS for it also?
(to possibly compare them)
My 1st thought seeing those characters I thought it was an axle code.
The GY axle is 3.08 but in a Firebird.
Old 11-23-2020, 06:34 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
It's your transmission speedo gear, 22 tooth gray. Must be 3.55:1 gears.
So long, farewell.
Old 11-24-2020, 09:36 AM
Holeshot71's Avatar
Hey thanks for the help guys. That makes sense, it does have 3:55’s. Is there some literature that has this info? Couldn’t find anything here or on the interwebs.
John, I’m probably being paranoid but I’m hesitant to post this stuff these days..
Old 11-27-2020, 11:32 AM
I learned from looking several build sheets over the years.
Which is why people should share theirs with the certain people who seek examples. I don't have a list of who the certain people are, but John is one seeking to learn. I would be asking if this was a '70 model year.
So long, farewell.
