Old 11-29-2020, 06:29 PM
Default 1972 TRANS AM
Are there any owners of 1972 Trans Am’s out there that have a car built prior to January 1972 ? trying to find when the earliest car was built and some information on Formula steering wheels ,plastic valance ,and deluxe interior options ( Comfortweave vs. perforated inserts) any information would be welcome And appreciated. Input from 1972 formulas / Firebirds pertaining to the same information could also be helpful
Old 11-29-2020, 08:36 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
My 1972 T/A was built November 71. Standard interior, no valance when purchased and no evidence of plastic valance.
JIm
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 11-29-2020, 08:51 PM
unruhjonny's Avatar
I find part of this query to be interesting because I had understood that the comfort weave was not used after 1971;
I believe all sources cite the perforated material for 1972.
1970 Formula 400
Old 11-29-2020, 08:56 PM
tcom tcom is offline
Mine was built Nov. 71. Have a pic of it from 1973 and did have the plastic valence. Now it has a repo plastic valence. Car has deluxe interior with perfed inserts on the seats
Old 11-29-2020, 10:15 PM
Thanks for the info guys keep it Comin .I do remember comfortweave In 72’s early in the model year
Old 11-29-2020, 10:32 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Dec 71 build on mine. Not sure the build date on the formula.
standard interior on 72, deluxe on Formula
Both metal valance
Then again, those may have been changed over years of use.
Old 11-29-2020, 11:58 PM
Formulabruce's Avatar
I owned a early Dec'71 built '72 which came with a new style steel valence in the trunk ( new style as in will fit the clear capsule and amber capsules and the new wiring harness they take)
The one on the car was broken and dealership- was to paint match the new one.
I have a late Nov '72 that also came with a black ( primer ) steel valence and the "Clear" capsule which was used in about 1 month only)
This was painted to match by the dealership, but was on the car at delivery, not in the trunk.
The Dec built Formula had the new style gauges.
Another Dec '72 I owned had perf in the custom interior seats.
I have seen a 10C Trans Am many years ago.
Old 11-30-2020, 06:57 AM
Judge273's Avatar
Judge273 Judge273 is offline
My 12C Formula has a plastic valence, ICX formula wheel, and black buckle seat belt and no warning indicator. Standard interior. Bobs old 72 Formula built same time, had deluxe perforated and plastic valance too. Both clear plastic.
Mike/Illinois
Old 11-30-2020, 08:30 AM
455hota's Avatar
455hota 455hota is offline
A small request if some can help me out please:
Can someone post a closeup pic of perforated vinyl? I don’t recall ever seeing this material.
Thanks in advance, just trying to learn some more Pontiac info...
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 11-30-2020, 12:28 PM
Old 11-30-2020, 01:19 PM
I don't know if this helps, but I know of a 72 Formula 455HO project car that I was thinking of buying sometime back. It's a Sundance Orange car with deluxe covert interior (which is missing). I sent to SMS for fabric samples and this is what they sent me. The sample has perforated vinyl, not comfortweave. The build date on the cowl is 12B and it has the seatbelt warning light in the speedo. No front clip, so no valance.
ID:	555088   Click image for larger version
Old 11-30-2020, 01:42 PM
Here are some pictures of a very original 1972 Esprite four speed car that was for sale a year or two ago. This was a one-owner car with 21K original miles on it. It had deluxe covert interior, with perforated vinyl. There were no pictures of the cowl data plate, but according to the Protecto Plate, it was sold new on December 11, 1971. It did not have a seatbelt warning light in the speedo.
ID:	555091   Click image for larger version
Name:	Rear Seat 1.jpg
ID:	555092   Click image for larger version
Name:	Rear Seat 2.jpg
ID:	555093   Click image for larger version
ID:	555094   Click image for larger version
Old 11-30-2020, 07:56 PM
necdb3's Avatar
necdb3 necdb3 is offline
518 vin 72 F455 plastic valance, standard interior, clear lens, no belt minder.
Old 11-30-2020, 07:57 PM
455hota's Avatar
Thanks Chris. Yes those pics are what I was looking for. Perforated vinyl is as the name implies, vinyl with holes! Now I know. Thanks!
...Steve T.
Old 11-30-2020, 11:47 PM
ICX formula wheel?
Old 12-01-2020, 04:26 PM
Transamric's Avatar
10D Esprit, perforated, poly valance (orig.), clear signal lenses, '71 style front belts so no belt reminder light and no Formy wheel.
The Following User Says Thank You to Transamric For This Useful Post:
Old 12-01-2020, 07:06 PM
necdb3's Avatar
Originally Posted by Tellyshavilli View Post
ICX formula wheel?
Not sure on the wheel, I think it was IC but not 100%
The Following User Says Thank You to necdb3 For This Useful Post:
Old 12-01-2020, 11:19 PM
4birds's Avatar
4birds 4birds is offline
I had a very early 72 HO Formula. (09E) Factory black cloth (236 trim code), metal valance (unknown if original), clear park lenses, no belt reminder in the speedo, no Formula wheel. Seat belts missing. I also had an early (10B) Esprit with the covert beige cloth interior. Very unusual 1 year only material.
Name:	72 HO 2.jpg
ID:	555202   Click image for larger version
Name:	72 HO Cloth.jpg
ID:	555203   Click image for larger version
ID:	555204   Click image for larger version
Old 12-01-2020, 11:37 PM
Transamric's Avatar
Here's another I let go; 2U87N2N501731, 09A, poly valance (orig.), clear park lenses, no seat belt warning lamp, '71 style front belts, 222 (221) White perforated.
Old 12-01-2020, 11:38 PM
4birds's Avatar
I have 2 72 T/A's. #1- 12A build with black deluxe vinyl (trim code 226). Has the seat belt reminder in the speedo, but no wiring to it. Custom belts (not retractable). Had a plastic valance with clear lenses. ICX Formula wheel. #2- 03A build (late) Plastic valence with amber park lenses, ICX Formula wheel, retractable belts with functioning reminder in the speedo. (wiring to the retractors and dash)
Name:	72 12A ICX.jpg
ID:	555206   Click image for larger version
Name:	72 12A belts.jpg
ID:	555207   Click image for larger version
ID:	555208   Click image for larger version
Name:	72 TA 12A cluster.jpg
ID:	555209   Click image for larger version
Name:	72 TA 12A delux.jpg
Thread Tools
Display Modes
