#41
He also will need a replacement shaker scoop and breather pan from an original 77-79 400 Pontiac TA. Olds 403 TA stuff is offset. Quote:
You can check for bent rod / compromised piston with a dial indicator on the deck surface after head is off. Thats about all you can do, and cross your fingers. Or tear the whole thing down. Sometimes you just have to roll the stones and go for the easy button. Edelbrock Aluminum heads are cheap for Olds compared to Pontiac, is what someone was referring to with that suggestion. Worth comparing just to know the best way to spend before getting too deep into the stock heads. Free shipping and ready to run from places like Summit and Jegs - maybe eBay. I'd want that 403 out of my life if it was my car. But that is very very bias and prejudice I'm thinking the 403 cars came with THM350 tranny, not THM400 Not an issue, just a side note. If it wasn't a special keeper car, i'd probably try to reconcile with the 403 Olds. |
#42
Thanks for your comments. I will further investigate when I get the opportunity. I want to at least pull the head(s) while the engine is in the car and see what I have. Maybe upgrade the heads to higher compression if I stay with the 403. At the very least, repair what I have in the 403, if it is reasonable in cost, and shelf the engine as it is the original.
Is there any resale value in staying with the original motor or is there more value with the available Pontiac 400 that I have. The Pontiac 400 is newly redone with all new components and extensive headwork - it has a performance cam for automatic transmission - should dyno around 400hp. Is an automatic or manual more desirable for resale. Seems like most here think I should go with the Pontiac 400 - I should have all the brackets needed. Quote:
#43
Steve F. |
#44
Some guys just mount the shaker to the hood and use an aftermarket breather after doing a 403 removal. Its cheaper and looks cheap - but its done to a lot of modified cars. Depends on what you're after and what kind of originality you want to maintain.
Big Builds usually have little to no choice. Forget all about being able to modify the 403 shaker set-up to fit in a stock manner with a Non-Olds engine. it don't be gunna work no mo for all the time and trouble it would take to modify each piece. If you go there, you'll see All the other questions depend on what you value your parts at. If around Zero - you can't get hurt. Long story-short , if you aren't keeping the car, let the next guy pick his own upgrades and mods. All you'll do is lose money and parts when you go to sell. Consider how much money the last guy lost when he sold you the car. Most everyone here would almost instantly swap the 400 you have if they planned to keep the car. On the other hand, they would all patch the 403 back up if they knew they were going to be selling it soon or within a couple few years. You'll just be giving your engine away. Now if its a really sweet cream puff with deluxe interior and in excellent condition inside and out, the variables change quite a bit. At that parameter, you might could break even or gain a little - if you value your engine at around $3000 or less. |
#45
