Old 08-12-2020, 11:27 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default 67 Ram Air on Ebay
Saw this on Barnfinds today Calif. YR code
https://www.ebay.com/itm/224103847774
The Following User Says Thank You to Sloan66 For This Useful Post:
Old 08-12-2020, 12:20 PM
Sloan66's Avatar
It is also listed in the forum for sale area, nice car
Old 08-14-2020, 11:00 PM
Very rare car in good condition.
I don't have much experience with California cars,
Wasn't aware they charged so much for the AIR stuff on them.
Guessing the heads have been changed on the engine -
no signs of AIR provisions.
Which version of heads would a Nov 66 build have gotten ?
Old 08-15-2020, 12:22 AM
242177P's Avatar
242177P 242177P is offline
I suspect you're thinking of the Chevy style A.I.R. setup. Like two injector tubes
with four ports each threaded into the exhaust manifolds? Pontiac kept things
much cleaner by just using brackets mounted on the front of each head.
HTH.
Old 08-15-2020, 07:38 AM
My notes for 67' YR shows 97 heads with AC.
Bet it's suppose to be AIR instead of AC.
Clay
Old 08-15-2020, 07:57 AM
DANTIP DANTIP is offline
Default AIR
All 670 heads have the AIR passages. You can see the cast-in passage that goes the length of the head just below the valve cover. The '67 RA cars used a mix of heads. The first were modified '670 castings the later heads had a unique casting number (which I cannot recall). Notice the EUN on the PHS matches the engine stamp. Very unusual to see a real-deal "matching number" 4-speed RA!!
Very rare car indeed. Here's what the smog system looks like on the CA RA cars.
The Following User Says Thank You to DANTIP For This Useful Post:
Old 08-15-2020, 12:49 PM
I was thinking semi-chevy type system with lines tapped straight into the heads at the machined bosses on the rail below the valve cover area.
Years ago read that was what the provisions were for, but i guess Pontiac one-upped that layout.
Thanks for the pictures and explanations.
Supposedly there were 3 versions of heads used.
670 with no outer mods
670 with 6 and 0 ground off - and 99 stamped alongside the 7
Then finally a cast 997 head.
The only 2 cars i have seen both had the ground off version.
Probably call this one on the tail end of an "early" RA 67 car.
Only 64 YR cars produced according to end of year engine production stats.
YQ (Auto AIR) doesn't even have a stat listed, may have been 0
Also think the YR code threw some bid prospects off track
thinking it was an Automatic converted to 4spd
its a wacky code
Old 08-15-2020, 01:23 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Here's a photo showing the open passage ports just outside of the freeze plugs. They are threaded for screw-in plugs on cars without A.I.R..
The Following User Says Thank You to 428ho4spd For This Useful Post:
Old 08-15-2020, 05:16 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
There are a couple items in the first photo that pertain to it’s A.I.R. equipped engine.
1) Aluminum alternator bracket with provision for Smog tube.
2) Double pulleys on alternator.
Plus the heater hose attached to the RH fender skirt.
The ‘67 illustration showing both cylinder head “plugs” that would be removed for the A.I.R. system, plus the special aluminum bracket.
Looks like there is at least “1” of the ‘67 R/A with automatic and A.I.R. (YQ) which was a test car.
ID:	547288   Click image for larger version
ID:	547292   Click image for larger version
ID:	547293   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 08-15-2020, 06:28 PM
Keith Seymore's Avatar
Back in my day I know there were a couple pickup truck configurations where a quantity of 2 were built....and they were both power train test vehicles.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 08-16-2020, 11:49 AM
I don't know what to think about how they didn't list out YQ
The penciled in notation is way after the fact, by Fred.
They would have been produced stamped & long-blocked in Michigan
Oversight or Zero ... idunno
I suspect bigger buyers aren't as attracted to a YR coded car with plain looking 670's.
XS with later heads would be the golden geese.
I can kind of relate to that
Color change was odd to Silver
I'm not a Gold fan either though
He's got an ultra rare 67 GTO
I would get together a better detailed in-depth description,
include more pics and info about the completeness of the AIR and Carb,
and list it on Bring-a-Trailer.
Old 08-16-2020, 07:56 PM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Great car with original motor. Just needs a total resto in my opinion. Worthy
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 08-16-2020, 09:36 PM
I Agree, Full Worthy
But i'd settle for an underhood detail, trunk floor fluffing,
and a set of Rally Ones . Maybe a set of ladder bars
Glasgo didn't you have a Plum Mist 67 R/A car ?
Old 08-17-2020, 04:19 PM
Sloan66's Avatar
Did all 67 Ram Air's get the 744 cam?
Old 08-18-2020, 06:04 AM
J GLASGO's Avatar
No. Would love to
Old 08-18-2020, 10:06 AM
Somebody posted a few pictures of a 67 Plum Mist R/A car a few years back and can't remember who it was now.
Have only heard tale of maybe 12-15 of these cars in the last 30 years.
I think another PY member has an Automatic (maybe White iirc)
Name:	67 ram air plummist1.jpg
Old 08-18-2020, 04:08 PM
60sstuff's Avatar
Mr. BVZ,
Here ya go.
Supposedly a 67 R/A in Plum Mist.
Suspended member.
CT
Old 08-18-2020, 05:01 PM
Damn
CuznGreg owned it
He's owned about one of everything except a Ram4 JudgeVert and TA Vert
Believe its the same car as my picture too.
5-6-7 years ago there was a Tyrol Blue 4spd RA with a longtime owner on eBay.
maybe even the original owner
Had 69 Ram4 head upgrade back from when Ram4 came out.
The bids started going up and he got cold feet and ended the auction.
Never heard anything else about it.
Old 08-19-2020, 06:24 AM
J GLASGO's Avatar
That was a dark blue car. I had just bought a low mile 67 when this popped up. I should have bought it. It was really cool!
