Old 12-25-2023, 05:29 PM
MIke L MIke L is offline
Default Cleaning inside oil breather cap / ATF for PS
Merry Christmas to everyone!!
2 quick questions if I may….
1st
I want to clean the inside of my oil breather cap on my ‘65. 389
Anybody ever do that?
If so how did you do it, if at all?
2nd
What ATF do you guys use in your power steering reservoir??
Mike
Old 12-25-2023, 10:06 PM
242177P's Avatar
242177P 242177P is offline
Grab a flashlight and peer inside, the AC breather's
guts are nothing more than a piece of coarse steel
wool. Use whatever solvent you have on hand?
Can you use ATF? Sure. But it ain't right, best to just
use proper power steering fluid. Apparently pumps
live longer. Dunno.
Old 12-25-2023, 11:29 PM
Kerosene or even diesel fuel work well for cleaning the breather. Please don't use gasolene.
Old 12-26-2023, 08:17 PM
Thanks Guys
Mike
Old 12-26-2023, 09:24 PM
Mineral Spirits... it's what I have in my parts washer.
Old 12-26-2023, 10:08 PM
giles's Avatar
giles giles is offline
Inspect the steel wool inside the cap carefully. I found the steel wool was a bit rusty and shedding bits. I did not want that stuff contaminating a fresh build so I dug it all out and flushed thoroughly with parts cleaner. I now have an empty but correct looking breather cap.
