THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
A scissors lift blocks the bottom of the car, and the lift height just seems awkward. Too high to lay on your back, too low to stand up. Working with your arms up in the air while sitting on a stool while trying to work around some cross-braces didn't seem like my idea of fun. Also, a scissors lift takes up a lot more room to store. Not to mention that if your garage is nor very tall that can constrain how high you can lift the car anyway.
Check out my cruise night! www.brewcitycruisenight.com |
I think I'm going to order one but it will ll be the next step up, the one rated for 3 1/2 tons.
that's the one I have on order. They are on back order right now. I also added the SUV extensions for my JEEP and I guess I could also use them to get the Pontiac extra high if need
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
Love to have one a those, I'm jealous.
You can call me Big Chief Jack A lot On second thought make that Little Chief Liftless Just make that Chief Foot In Mouth
Poncho Huggen, Gear Snatchen, Posi Piro. |
The Following User Says Thank You to 4zpeed For This Useful Post: | ||
I've toyed with getting one of these for years. How about this one? 30" lift height with three separate stopping heights. Don't know what those are...
https://www.bestbuyautoequipment.com...waAltHEALw_wcB
Greg Reid Palmetto, Georgia |
I hate to sound like a Quickjacks fanboy but I guess I kind of am.... Best $1340 I've spent on car/garage/tools stuff. My only regret is that I didn't get them sooner.
The final decision maker for me was when I got my Aston Martin - there is just no way to work on this car using jack stands., some sort of low-profile lift is a necessity. It only has 3-1/4" of ground clearance and the Quickjacks just fit underneath. The photo shows the lift at the lower of the 2 lock positions.
[QUOTE=Blue1967GTO;5780437]That looks like a clunkier version of Quickjacks. Less versatile, far heavier, not portable at all.
I was thinking the same thing. |
I did not see a weight on the Ranger...what would you estimate that to be?
212 pounds total gross weight. Heaviest section is 76 pounds.
https://www.quickjack.com/car-lift-s...-car-lift.html |
The Following User Says Thank You to The Champ For This Useful Post: | ||
Big difference. Thanks Mike.
Plus, the Quickjack has rollers on one end of each section so you don't have to pick up the whole thing to move it.
1974 Firebird Esprit 1953 Buick Special Riviera 1963 Riviera 1963 Thunderbird 1965 Mustang 1965 Skylark Sport Coupe 1965 Dart 170 Wagon 1965 Corvair Monza Convertible |
The Following User Says Thank You to Aaron65 For This Useful Post: | ||
Cool. This might be a good investment for me since in the last year I had a concrete pad and carport installed off my driveway. Pad's not thick enough for a real lift but this would work and I can move it back and forth between the carport and garage. Plus, if I move, it goes with me.
Here's another awesome thing about the Quickjacks - here we are at the racetrack fixing our Chump Car. Small and light enough to be portable, and with the 12V power source it is easily powered by a cheap battery jump box.
I'm really liking this piece of equipment. After I get some tires for the truck, I'm going to start saving my nickels for this. Thanks for the good info.
I want one of these lifts. Perfect for me.
72 Bird |
Here's another picture, right after I assembled it, from a different perspective. My driveway's a little angled, so I don't think I'd leave it here, but it shows the space underneath.
Sorry for the Ford picture on a Pontiac website.
#39
I finally set up my new 7000 quick jack. Pretty cool. HEAVY.
Does anyone know if it matters whether I leave the lines connected or not when not in use?
#40
Per Quick Jack's instructions, the lines can be disconnected. Each time I use mine I disconnect the lines.
There is no such thing as too much cam, just not enough engine. 1966 GTO - 11.31@119 (3478 lbs) in 1979 1967 Firebird - 9.73@138 (2940 lbs) in 1986 400 cu in / 295-298 cfm RAIV / Lunati Cam 278/283 - .704 lift/5.13 gears |
Thread Tools | |
Display Modes | |
