Old 10-24-2021, 04:33 PM
Greg Reid Greg Reid is online now
Originally Posted by Longs View Post
What is a "good price" for a Quickjack? I just received an ad from Costco for $100 - $200 off, depending on model. It appears that the BL-5000SLX is $1,099 after the $100 off. The same model with four pinch weld blocks and wall hangers is $1,199 after the $200 off.
I think that's a pretty good price. My 7000 was about $1300 and change after a discount. I may have been able to save the tax had l not bought from Home Depot.
Sent from my moto g stylus (2021) using Tapatalk
Old 10-25-2021, 12:44 AM
dataway's Avatar
dataway dataway is offline
I paid $1400 including tax for my 5000 a month or so ago, and that was a couple hundred less than I saw it other places. So yeah, around $1100 is a great deal. Heck, I was happy with $1400 ... but then the wife paid for it
  #143
Old 10-25-2021, 12:21 PM
Actually, I'll have to correct myself as I paid closer to $1,500 for my 7000 after tax, delivered. The 5000 was like $1,300 at that time. So yeah, I'd say it's a good price.
Old 10-25-2021, 02:13 PM
padgett's Avatar
padgett padgett is offline
Agree cannot buy a real lift for anything close to a large (more like 2+). Black Friday is coming soon.
Web Site
  #145
Old 10-25-2021, 06:21 PM
The Champ's Avatar
I paid $1025.00 for mine over 3 years ago. With today's inflated pricing, $1199 with the 4 pinch weld blocks is a decent deal.
  #146
Old 10-25-2021, 07:28 PM
Dadspackard's Avatar
Dadspackard Dadspackard is offline
When I first went to place my online order with Costco it stated out of stock item. Went back in after work and was able to place an order for one. 1,274.99 with tax.
Can't come soon enough. Need to do rear wheel bearings on my '69 GTO.
Tom
  #147
Old 10-25-2021, 11:25 PM
67TIGER's Avatar
67TIGER 67TIGER is offline
I ordered one last night from Costco.
Can't wait to try it out.
All the comments here have been very helpful.
Thanks for all the information, it convinced me to purchase one.
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
GTO-The Great One for 1967
  #148
Old 10-26-2021, 08:05 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
For a 71 firebird. What are your lift points? Pinch welds?
Any attachment needed?
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
  #149
Old 10-26-2021, 09:18 PM
The Champ's Avatar
We have a '72 Camaro - same thing as your Firebird underneath.
Using the pinch weld blocks and locating them behind the front wheel wells and in front of the rear wheel wells works just fine.
See photo below.
  #150
Old 11-01-2021, 05:23 PM
Received my quickjack yesterday. There was no shipping or deliver email from Costco. Fedex just showed up with it.
Assembled it today and brought it back to where I am living and where I have the GTO.
Figured I'd give it a try on my daily driver 2015 Ford Edge. Took a few minutes to get the blocks lined up on the pinch wells but overall not to hard to do. It is pretty solid even using three blocks.
Next is to get the GTO up in the air to pull the rear axels for bearing replacement.
Overall I am pretty happy with this purchase.
ID:	576752   Click image for larger version
Tom
The Following User Says Thank You to Dadspackard For This Useful Post:
  #151
Old 11-01-2021, 06:31 PM
Could resist. Got the GTO up in the air.
Tom
  #152
Old 11-01-2021, 06:44 PM
padgett's Avatar
" That's why I didn't get a scissor lift, even though they usually lift higher;" Mine has 34" clear between the ramps. Don't know of any tranny that wide (most GM bellhousings are 20" max).
Web Site
  #153
Old 11-01-2021, 07:53 PM
Nice lift Padgett. What brand is that?
Well do you all think my passengers side bearing is still good to use.
Tom
  #154
Old 11-01-2021, 09:09 PM
padgett's Avatar
Mine is NLA, Equivalent now is an Atlas Kwik Bay 7,000 Lb. Mid Rise Lift. Might get a little smaller one today, have no need to lift over 4700 lbs.
Web Site
  #155
Old 11-02-2021, 04:05 AM
dataway's Avatar
Still loving mine, just tonight I was down doing some interior work and noticed a small rust hole that I somehow missed. Car was already up on the QJ ... easy access to the bottom side to check out what needs to be done. Keeping a car in restoration lifted up that 20" or so at all times makes it so easy to shift from one job to another. I used to have to sort of schedule UP work or DOWN work, now it's no big deal make the height changes.
  #156
Old 11-03-2021, 09:02 AM
F ROCK's Avatar
F ROCK F ROCK is offline
i've got the 5000lb quick jack and i like it.
How are you folks supporting the nose of the car?
I've got a '71 GTO with the endura. I've always dreaded jacking the front end because while jacking one side at a time, the frame twists a little bit and sometimes enough to crack the paint on the endura.
No twisting with the quick jack, but the nose, engine, wheels and front suspension are hanging there. That might be most of the weight of the car. The gap between the hood and bumper grows tremendously while on the QJ.
I once left another '71 on jackstands for several months and i think it sagged after that.
I plan on doing a disc brake conversion soon, so my car will probably be elevated for a while.
  #157
Old 11-03-2021, 09:50 AM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
On my 72 I haven’t noticed any gap change , I’ll have to take a look. I have a 5 year old 5000 model and using the lowest safety catch it keeps the tires about 2 inches off the ground, car is always up on the quick jack when I’m not driving it. I put the jack about an in or so behind the front tires before jacking it up, catches the frame right in front of the crossmember.
  #158
Old 11-03-2021, 01:00 PM
dataway's Avatar
Look at this way ... being up on the QJ for months my help to un-do the decades of the weight of the car resting on the front wheels and the frame sagging the other way
I have my front blocks pretty much right on the heavily reinforced front "turn-in" on the frame, don't see any sagging when it goes up.
A car frame should flex without issues, just because it flexes doesn't mean it's bending. Takes many, many years for something like a frame to take a "set" .... in this case any set would go away the minute the car was lowered to the ground.
  #159
Old 11-17-2021, 05:34 AM
dataway's Avatar
Wondering .... anyone start their car while up on a QJ ? Would come in handy for doing some driveline and brake tests.
  #160
Old 11-17-2021, 06:15 AM
The Champ's Avatar
I have. After changing oil, but before lowering vehicle, start to insure no leaks, no drips, no errors....
The Following User Says Thank You to The Champ For This Useful Post:
