Raditor Hoses / Belts
I have a 69FB Sprint and I am looking for a set of upper and lower radiator hoses. Some time ago there was a post about using a more common hose and cutting it down to make it fit.
Anyone have a part they know of that will fit? I am also looking for replacement belts for alternator and power steering. Any ideas where I can these? |
If you run your type of Pontiac on most of the Auto parts sights I'm sure they will have you listed. I think all the replacment upper hoses are a cut to fit.
Here is my Nappa/Gates belt list for 66-67 A-Body might be the same. PS-ALT 25-06853. PS-ALT-WP 25-13103. AC 25-14483 or 25-7570 GATES. Hoses I know are not the same, as the FIREBIRD has a longer nose.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks Jeff. I'll give NAPA a try and thanks for the part numbers
I actually dug through my buddies auto supply store and found that a upper hose for a grand cherokee fits with a little cutting. 2000-2004 4.7 v8 was the app. you could try that.
69 Trans AM RAIII Auto 69 Firebird 350 HO 4spd Black survivor |
1 1/2" x 10 19/32" 2000 GC 4.7 SOHC |
go here
