Old 01-02-2024, 01:45 PM
sglemans sglemans is offline
Default What is this piece of sonething
I was cleaning/scrubbing around the steering box area and this small black foam square fell out to the floor, about maybe 3" x 5". Is this anything important? Will get a pic shortly
Old 01-02-2024, 03:10 PM
There’s no foam of any kind around the steering box, but there is a rubber mud flap hanging off the wheel well that’s used to cover most of the gap between the upper control arm and the wheel well.
The other possibility is that it came off of the air sealing material around the radiator.
Old 01-02-2024, 06:10 PM
Talking
That could be it
Pic, complete with spotlight
Old 01-02-2024, 06:12 PM
Talking
More like 2x1, a bit smaller than I thought
Old 01-02-2024, 06:19 PM
I haven’t a clue !
Old 01-02-2024, 06:32 PM
dataway's Avatar
dataway dataway is offline
Looks like the pre-vulcanization form of the material that is pressed into a McGanzer Flange gasket.
Old 01-02-2024, 09:50 PM
4dblnkldude's Avatar
There you go again. LOL. It doesn't look like anything to me. Could be anything picked up on the road, maybe someone put it there.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 01-02-2024, 10:08 PM
Talking
Thx, just wanted to be sure I didn't knock some kind of shim out of place or something
Old 01-03-2024, 06:49 AM
I think you knocked loose the start of a winter aboe for a Mouse.
Old 01-03-2024, 07:48 AM
dataway's Avatar
Seriously .. not knowing the history or usage of the vehicle ... I'd guess at some point that piece was either a slightly sticky piece of debri on the road that got tossed up, or perhaps a previous owner stuffed it somewhere to separate two components (hoses, lines etc), prevent a rattle etc.
Old 01-03-2024, 11:21 AM
george kujanski's Avatar
Some previous owner add-on.
George
Old 01-03-2024, 06:08 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
I think that is a muffler bearing that went flat?
Or the watchucallit valve that lost its air?
Old 01-03-2024, 07:46 PM
Those gaskets not avail anymore, because the diluvian carbonic expresser foam equipment was banned for causing blackened hand, arm and eye socket.
Old 01-03-2024, 08:10 PM
P@blo's Avatar
P@blo P@blo is offline
Hashish, aka stashish perhaps?
Old 01-03-2024, 08:25 PM
gto4ben gto4ben is offline
Based on the material color and texture, I'd say it's a piece of cork insulation tape that found it's way into a crevice.
Name:	Cork Insulation Tape.jpg
ID:	625915   Click image for larger version
Name:	Cork Insulation Tape-Front.jpg
Old 01-03-2024, 08:58 PM
Scott Stoneburg's Avatar
I would guess it's a piece of insulation from the firewall
Old 01-03-2024, 09:30 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Not sure what car that's from but looks like it could be a long lost air cleaner vent PVC breather filter...
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
Old 01-03-2024, 11:12 PM
Tim Corcoran's Avatar
Looks like a petrified kotex
Tim Corcoran
Old 01-04-2024, 05:27 AM
chuckies76ta's Avatar
^^ hahahaha.
Old 01-04-2024, 08:11 AM
dataway's Avatar
Hehehe ... Wow
