What is this piece of sonething
I was cleaning/scrubbing around the steering box area and this small black foam square fell out to the floor, about maybe 3" x 5". Is this anything important? Will get a pic shortly
There’s no foam of any kind around the steering box, but there is a rubber mud flap hanging off the wheel well that’s used to cover most of the gap between the upper control arm and the wheel well.
The other possibility is that it came off of the air sealing material around the radiator.
That could be it
Pic, complete with spotlight |
More like 2x1, a bit smaller than I thought
I haven’t a clue !
Looks like the pre-vulcanization form of the material that is pressed into a McGanzer Flange gasket.
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
There you go again. LOL. It doesn't look like anything to me. Could be anything picked up on the road, maybe someone put it there.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
Thx, just wanted to be sure I didn't knock some kind of shim out of place or something
I think you knocked loose the start of a winter aboe for a Mouse.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Seriously .. not knowing the history or usage of the vehicle ... I'd guess at some point that piece was either a slightly sticky piece of debri on the road that got tossed up, or perhaps a previous owner stuffed it somewhere to separate two components (hoses, lines etc), prevent a rattle etc.
Some previous owner add-on.
George
I think that is a muffler bearing that went flat?
Or the watchucallit valve that lost its air? |
Those gaskets not avail anymore, because the diluvian carbonic expresser foam equipment was banned for causing blackened hand, arm and eye socket.
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Hashish, aka stashish perhaps?
Based on the material color and texture, I'd say it's a piece of cork insulation tape that found it's way into a crevice.
I would guess it's a piece of insulation from the firewall
Not sure what car that's from but looks like it could be a long lost air cleaner vent PVC breather filter...
Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
The Following User Says Thank You to 4zpeed For This Useful Post: | ||
Looks like a petrified kotex
Tim Corcoran |
^^ hahahaha.
Hehehe ... Wow
