Old 01-14-2024, 09:41 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Default victor dominator intake on a 400
what do you guys think...im dropping a couple 400 blocks off at the machine shop next week, one for a 434 blower build....the other is just for the helluvit but iam taking the eagle h beam rods and ross pistons and stock crank to be balanced too.
for this extra 400, i have
sm 78cc heads flowing an advertised 310cfm or the edelbrock dports 72cc out of the box.
xr288 cam.
intake could be
victor dominator
torker 2
possibly 66 tripower if this motor makes its way to my 66 although i really want that on a 455 ive got hanging around
what kinda power u think is possible...and how do you guys think the victor would do on smaller cubes like this?
and other than the specific lifters i have the stuff to try out the ls lifter retro fit
Old 01-15-2024, 12:01 AM
chuckies76ta's Avatar
Torker 2 would work good. Victor 4500 is too big for a 400 in my opinion.
Old 01-15-2024, 05:50 AM
Dragncar Dragncar is offline
Well, I know a fella who ran 11 flat with one on a 400 with a RAIV cam. 750 carb.
Heavy 2nd gen too.
Late block and after 3 or so years it severely cracked every main web.
Old 01-15-2024, 05:24 PM
Tim Corcoran's Avatar
With a 400 cube motor if you had some real good breathing heads 320 plus CFM some decent compression and a big solid roller cam then a Victor may be a good choice. For your combo I think it would slow velocity may have a weak carb signal and be down on HP. Oh it would work but just not as good as other manifold choices.
Tim Corcoran
Old 01-15-2024, 05:59 PM
Pontiac Performance Author
In the Feb 2012 Car Craft we dyno tested a 535 ci pontiac with SD/Edelbrock heads of 340 cfm. Cam was a 248/256 hyd. roller. The Victor was down on power all the way to 5600 as compared to the Torker 2. The Victor tied with the T2 at 5800 and the power curve was flat at that rpm. The peak power was 635. The Performer RPM was strongest to 4500 RPM
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 01-15-2024, 07:30 PM
Steve C. Steve C. is online now
Here is the article Ken mentions if interested.
https://www.motortrend.com/how-to/cc...-alloy-indian/
Note in the picture gallery the Torker II intake with the welded ports. The manifold ports were too short for the tall CNC ports on the cylinder heads and required TIG-welding raised port tops, which needed to be machined flat and port-matched.
Old information here:
Old 01-15-2024, 08:23 PM
dang i was hoping to put one of these victors to use, but its lookin like i might just have a 400 with a ehead d ports and a tripower on standby.
honestly if i could manage to put together a 450 hp or better 406 out of these extra parts id be happy
Old 01-15-2024, 08:52 PM
steve25 steve25 is offline
You should be able to make a easy 450 Hp out of any aluminum head even if it’s flowing only 260 cfm.
Go find this article from the Apr 1992 issue of HPP magazine.
Note this level of power was made with a untouched T2.
ID:	626636   Click image for larger version
Old 01-16-2024, 02:11 AM
Stan Weiss's Avatar
Steve,
Do they show any dyno sheets? These avg BSFC numbers look better than most engines best BSFC.
Stan
Pontiac Pump Gas List
Old 01-16-2024, 07:28 AM
Stan here’s they dyno sheet from that motor that Pete sent me back then.
I will post it up in 3 photos so you can zoom in better.
In looking at the power anomalies from 5700 rpm on up I think I would really call that 400 a 467 Hp motor, what do you think ?
ID:	626658   Click image for larger version
ID:	626659   Click image for larger version
Old 01-16-2024, 11:10 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Nothing noted in the article of the drilling between the webs in the lifter valley I assume to increase drainage and maybe drilling the "421 hole" on the deck?
I had to add weld to my T2 to match a 320 cfm E head-ground and blasted mine to look prettier
Makes me wonder if my IA Camaro might pick up bottom end going to a T2 since I have a soft 60 ft. When we dynoed it the Dominator on an adapter did not make any more HP that the 4150 like his test.
Skip Fix
Old 01-16-2024, 11:43 AM
PAUL K's Avatar
PAUL K PAUL K is online now
The Victor shines on a 400 if the engine makes productive power above 7000 RPM. Not a lot of serious effort smaller cubic inch Pontiacs are built. The bigger engines make more power through out the RPM range and at lower level.... RPM=$$$
Go fast, see Elvis!
Old 01-16-2024, 12:43 PM
ok foor poops n giggles. sake.
same 71 400 .030.
ross flat tops
bme rods
ultradyne sr cam 271/279 @050
.426 lobe on a 104 lsa
and the victor
seams like a lot of cam but it would put the power band up where the victor could work,i just dont know it its enough compression for that much cam in a small motor
Old 01-16-2024, 01:49 PM
You seem to be really hung up on building a sub-performing 400 regardless of info presented to you.
Your posting in the competition section so if you want to run that cam in a 406 cid motor then get 12 to 1 into that motor, or pick a different cam.
Old 01-16-2024, 02:16 PM
PAUL K's Avatar
same 71 400 .030.
ross flat tops
bme rods
and the victor
Your best chance to amaze all your friends and use
your existing parts would be to install that cam at 100 ICL and measure your valve to piston clearance. Mill the heads to allow the the minimum. Look for a deal on a 750 cfm 4500 and tune that. The combination will most likely perfer 1.5 ratio rockers.... Sounds like a fun project.
Go fast, see Elvis!
Old 01-16-2024, 03:25 PM
steve25? are you mad?....lol....relax brother take a breath....it aint that serious
Old 01-16-2024, 03:46 PM
Default 👍
thats really all this 400 was intended to be was project....kinda a frankenstein....lol i just hated seeing the block out there getting used and i had this stuff on hand. the sr cam and victor was intended for a 455 but i couldnt help but think how it woukd do in a smaller cu in....lol with all the 1k horse ls cars out an about now....its hard for even a 600hp loley pontiac to get attention😁
Old 01-16-2024, 03:51 PM
Not at all!
But at least now I know this was just started by you to be a BS session, lol!
Old 01-16-2024, 04:35 PM
bull**** session?......lol look at you keeping the forums alive with your uplifting presence....i can see your piss poor attitude attracting the younger generations to the pontiac hobby by the....i dunno..single digits����
Old 01-16-2024, 04:59 PM
Skip: 421 cooler yes.
oil drain back yes. Only valley drain back is at the front of the valley. Bettcha 2 quarts would never return to the pan !
