Old 01-24-2024, 12:59 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
Default Leakdown test results update
An update of my previous thread below.
Hooked up a hose from my dipstick tube to a catch can and took it out for a 25 mile run with several 3/4 throttle blasts. The pics show how much oil is blowing out of the tube.
Did a test again and got 16% across all cylinders. Slight improvement on the 20%.
Engine is coming out at the weekend and going back to the builder for investigation.
ID:	627107   Click image for larger version
ID:	627108   Click image for larger version
69 Firebird
472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123
Old 01-24-2024, 03:07 PM
chuckies76ta's Avatar
That's alot of oil. Something is not right. Hopefully you get it done right.
