Old 09-04-2019, 04:21 PM
chemnick's Avatar
chemnick chemnick is offline
Default 1967 Restoration Parts-The Entire Updated List as of 9/4/2019
Updated 9/4/2019....Still interested in selling the remaining parts as a lot. Contact me via PM, please........thanks!
Bucket Seat Piping EA $10.00 1
Door & 1/4 Panel Trim Fastener EA $0.50 6
Door & 1/4 Panel Fastener Kit EA $5.00 1
Door & 1/4 Panel Trim Fastener Grommet EA $0.50 6
Door Top Inside Molding EA $35.00 1
Rear 1/4 Top Inside Molding EA $35.00 1
1964*67 Door and 1/4 Panel Watershed (Paper) EA $18.00 1
Under Rear Seat 1" Drain Plug EA $3.00 2
Kick Panel Vent Cable w/Knob EA $27.00 2
Kick Panel Control Cable Clip EA $1.00 2
Chrome "Speaker" Bezel for Dash EA $4.00 1
Climate Control Cable Set - No AC EA $45.00 1
Dome Light Lens EA $4.00 1
Dome Lens Reflector EA $13.00 1
Dome Lamp Bulb Terminals EA $3.00 1
Visor Bushing Kit EA $10.00 1
Headlight Bezels PR $170.00 1
Headlight Bezels Mounting Kit EA $6.00 1
Parking Lamp Lenses PR $32.00 1
Parking Lamp Lenses Gaskets PR $5.00 2
Parking Lamp Lenses Screw & Clip Set SET $3.00 1
Parking Lamp Lenses Bezels PR $30.00 1
1965-67 Headlight Adjusting Spring EA $1.00 4
Headlight Retainer Rings SET $16.00 1
Front Rocker Trim Left EA $30.00 1
Front Rocker Trim Right EA $30.00 1
Hood Bumper EA $6.00 2
Hood to Fender Bumper EA $1.50 2
Aftermarket Hood Scoop Non Ram Air EA $65.00 1
Exterior Door Handles EA $70.00 1
Door Lock Retainer EA $1.00 2
Left Door Lock Pawl \ $8.00 1
Right Door Lock Pawl / for PR 1
Right Door Latch EA $65.00 1
Left Lower Door Hinge EA $48.00 1
Right Lower Door Hinge EA $48.00 1
Left or Right Upper Door Hinge EA $45.00 1
Lower Door Hinge Roller Tension Repair Kit KIT $13.00 1
Door Hinge Repair Kit KIT $16.00 1
Door Striker EA $8.00 2
Window & Door Handle Retainer Cup EA $0.50 6
Left Door Window Regulator EA $60.00 1
Right Door Window Regulator EA $60.00 1
Vent Window Crank Pair PR $50.00 1
Screw-In Replacement Clip Studs SET $4.00 1
Windshield Wiper Arm & Blade Kit KIT $50.00 1
Wiper Motor 40-120 (Cardone) REMAN EA $75.00 1
Wiper Motor Transmission Retainer Clip EA $2.00 1
Backup Lamp Lens ea $14.00 1
Gas Door EA $30.00 1
(1964) Gas Cap - Vented EA $15.00 1
(1965-70) Gas Cap - Not Vented EA $8.00 1
Fuel Tank Straps (Surface Rusted) EA $30.00 1
1967 Wiring Diagram Book EA $5.00 1
Turn Signal Lever Cam Repair Kit KIT $6.00 1
Turn Signal Cancel Springs PR $2.00 1
Blower Motor Switch EA $55.00 1
Blower Motor Resistor EA $26.00 1
Stereo Front Speaker & Brackets EA $25.00 1
Fuel Pump w/Vent (Cardone) REMAN EA $42.00 1
Fuel Pump to Carb Line (S) EA $20.00 1
FT to Rear Fuel Line (S) EA $50.00 1
FT to Rear Vapor Line (S) EA $50.00 1
QuadraJet Choke Pull-Off EA 11.00 1
Choke Thermostat Housing, Coil & Rod EA $35.00 1
Cast Iron Thermostat Housing & Gasket EA $22.00 1
Thermostat Bolt w/Washer & Nut EA $4.00 1
1968-77 (11 Hole) Water Pump Divider Plate EA $20.00 1
Power Steering Pump Mounting Bracket EA $20.00 1
Throttle Cable EA $50.00 1
Blue Throttle Return Spring EA $6.00 1
Intake Manifold Gasket Set SET $20.00 1
65-67 Valley Pan Gasket EA $6.00 1
68-77 Valley Pan Gasket EA $5.00 1
D-Port Steel Exhaust Manifold Gasket Set SET $10.00 1
Starter Solenoid Heat Shield EA 13.00 1
Starter 323-256 (1893 723 GM) REMAN EA $90.00 1
Starter Solenoid D981 (1114458 GM) REMAN EA $45.00 1
1967-70 Q-Jet Throttle Shaft & Bracket EA $60.00 1
1967-70 Q-Jet Idle Mixture Screw EA $6.00 2
Carburetor Float EA $6.00 1
Crankcase Molded Vent Hose 90° EA $7.00 1
Steel Carb-to-Distributor Vacuum Line - Std. Trans. EA 12.00 1
"4-Q-66" Dated Ignition Wire Set SET 70.00 1
Delco Universal Plug Wire Set SET $30.00 1
Distributor Hold Down EA 12.00 1
Distributor Base Gasket EA $1.50 2
Distributor 30-1851 (Cardone) REMAN EA $70.00 1
Distributor Re-curve Kit (Points) KIT 10.00 1
Vacuum Advance VC-24A Standard EA $10.00 1
Contract Set EA 17.00 3
Condenser EA 8.00 3
Distributor Rotor EA 5.00 3
Ignition Coil EA $40.00 1
Distributor Cap EA 10.00 1
Standard Valve Cover Gasket Set (Rubber) SET $20.00 1
Outer Dip Stick Tube - w/o AC EA $25.00 1
Oil Pan Gasket SET $15.00 1
Cylinder Head to Block Alignment Pin EA $4.00 4
Pontiac V-8 Head Gasket EA $15.00 2
Fuel Pump Accentric - Light Surface Rust EA $35.00 1
Intake to Timing Cover Bolt & Clamp EA $8.00 1
Steel Engine Freeze Plug Set SET $11.00 1
Steel Cylinder Head Freeze Plug Set SET $6.00 1
Harmonic Balancer Bolt EA $7.00 1
Harmonic Balancer Washer EA $4.00 1
Black Nylon Compartment Strap EA $1.50 5
Non-AC Heater Core EA $80.00 1
Heater Blower Motor EA $30.00 1
Heater Box - Engine Side EA $30.00 1
Heater Hose to Head EA $12.00 1
Heater Seal Kit KIT $25.00 1
2" Fan Spacer EA $22.00 1
Radiator Cap EA $13.00 1
W. Washer Pump EA 1
Accelerator Pad Pin EA $2.00 1
Master Cylinder EA $50.00 1
Clutch Fork Boot EA $8.00 1
Clutch Rod Seal EA $8.00 1
Clutch Rod Seal Retainer EA $12.00 1
Shift Cable Floor Pan Grommet EA $5.00 1
Transmission Crossmember Insulator Brackets (Pr) PR $24.00 1
Rear Trans Mount EA $15.00 1
Hurst Shifter Mount Adaptor Plate EA $25.00 1
Bell Housing to Block Bolt Kit KIT $5.00 1
Flywheel Cover V-8 Standard Trans EA $30.00 1
Clutch Springs (2) PR $16.00 1
Clutch Fork Ball Stud EA $12.00 1
Clutch Countershaft Bushing EA $3.00 2
Clutch Countershaft Seal EA $3.00 1
Clutch Countershaft Bushing Spacer EA $5.00 1
Ball Stud Clutch Countershaft to Frame EA $10.00 1
Ball Stud Clutch Countershaft to Engine EA $13.00 1
Parking Brake Ratchet EA $80.00 1
Clutch Counter/Shaft Spring Clip EA $1.50 1
64-67 Ft Parking Brake Cable-Mt & Powerglide Tran EA $38.00 1
1964-72 Rear Parking Brake Cable EA $38.00 2
Mickey Mouse Brake Cable Clip EA $1.00 1
3/16" Push-In Brake Line Clip EA $1.50 1
1/4" Push-In Brake Line Clip EA $1.50 1
66/67 Brake Line Clip Set SET $28.00 1
Ft Brake Line Set (Steel) EA $50.00 1
Rear Brake Lines (R&L) (S) EA $20.00 1
Ft to Rear Brake Line (S) EA $40.00 1
Front Flex Hose Retaining Clip EA $1.00 2
Front Drum Brake Flex Line EA $17.00 2
Rear Brake Flex Line EA $20.00 1
Disc Brake Distribution Valve Bracket EA $15.00 2
Rear Brake Flex Hose Bracket (1968-72) EA $20.00 1
Rear Wheel Bearing EA $30.00 2
Rear Wheel Seal EA $8.00 2
Front Drum Brake Wheel Bearing Kit KIT $85.00 1
Clutch & Brake Pivot Shaft Bushing EA $3.00 1
Axle Flange Gasket EA $1.50 2
Ft Wheel Cylinder - Left EA $20.00 1
Ft Wheel Cylinder - Right EA $20.00 1
Rear Wheel Cylinder - R/L EA $15.00 2
1964-72 Front Drum Brake Spring Kit KIT $10.00 1
1964-75 Rear Drum Brake Spring Kit KIT $10.00 1
Rear Brake Shoe Guide EA $1.00 4
Parking Brake Spacer Bar EA $8.00 2
1964-72 Left Front Brake Adjuster Kit KIT $12.00 1
1964-72 Right Front Brake Adjuster Kit KIT $12.00 1
1964-72 Left Rear Brake Adjuster Kit KIT $12.00 1
1964-72 Right Rear Brake Adjuster Kit KIT $12.00 1
Upper Ball Joint EA $22.00 2
Lower Ball Joint EA $27.00 2
Inner Tie Rod End EA $65.00 2
Outer Tie Rod End EA $45.00 2
Tie Rod Adjustment Sleeve EA $10.00 2
Pitman Arm for Power Steering EA $65.00 1
Steering Center Shaft EA $100.00 1
Steering Idler Arm EA $40.00 1
Power Steering Pressure Hose EA $30.00 1
Power Steering Coupler (RAG Joint) EA $40.00 1
Upper Control Arm Bumper EA $5.00 2
Lower Control Arm Bumper EA $5.00 2
Rear Axle Bumper - Pair PR $15.00 1
Sway Bar Bushing - Pair PR $8.00 1
Sway Bar Bushing Retainer - Pair PR $10.00 1
1964-68 Front Drum Brake Wheel Stud EA $2.00 5
1965-77 Rear Wheel Stud EA $1.50 5
1967 Mark of Excellence Turquoise Foil Decal EA $4.00 2
Air Shock Decal EA $4.00 1
421-Tri-Power 425 HP Decal EA $4.00 2
Antenna Lead Firewall Grommet EA $15.00 1
Gas Pedal Rod Support EA $21.00 1
10-Bolt Rear End Cover Gasket EA $5.00 2
Just an old goat cruisin' in an old Goat........LIFE IS GOOD!!
Old 10-07-2019, 03:21 PM
chemnick's Avatar
Chemnick
Old 10-24-2019, 06:30 PM
chemnick's Avatar
Chemnick
Old 12-05-2019, 02:02 PM
chemnick's Avatar
Default Another Bump
Merry Christmas!!!
Chemnick
Old 12-12-2019, 04:33 PM
The Saint The Saint is offline
do you still have rear tail light bezels and lenses for a 1967 LeMans ?? Thank You
