1967 Restoration Parts-The Entire Updated List as of 9/4/2019
Updated 9/4/2019....Still interested in selling the remaining parts as a lot. Contact me via PM, please........thanks!
Bucket Seat Piping EA $10.00 1 Door & 1/4 Panel Trim Fastener EA $0.50 6 Door & 1/4 Panel Fastener Kit EA $5.00 1 Door & 1/4 Panel Trim Fastener Grommet EA $0.50 6 Door Top Inside Molding EA $35.00 1 Rear 1/4 Top Inside Molding EA $35.00 1 1964*67 Door and 1/4 Panel Watershed (Paper) EA $18.00 1 Under Rear Seat 1" Drain Plug EA $3.00 2 Kick Panel Vent Cable w/Knob EA $27.00 2 Kick Panel Control Cable Clip EA $1.00 2 Chrome "Speaker" Bezel for Dash EA $4.00 1 Climate Control Cable Set - No AC EA $45.00 1 Dome Light Lens EA $4.00 1 Dome Lens Reflector EA $13.00 1 Dome Lamp Bulb Terminals EA $3.00 1 Visor Bushing Kit EA $10.00 1 Headlight Bezels PR $170.00 1 Headlight Bezels Mounting Kit EA $6.00 1 Parking Lamp Lenses PR $32.00 1 Parking Lamp Lenses Gaskets PR $5.00 2 Parking Lamp Lenses Screw & Clip Set SET $3.00 1 Parking Lamp Lenses Bezels PR $30.00 1 1965-67 Headlight Adjusting Spring EA $1.00 4 Headlight Retainer Rings SET $16.00 1 Front Rocker Trim Left EA $30.00 1 Front Rocker Trim Right EA $30.00 1 Hood Bumper EA $6.00 2 Hood to Fender Bumper EA $1.50 2 Aftermarket Hood Scoop Non Ram Air EA $65.00 1 Exterior Door Handles EA $70.00 1 Door Lock Retainer EA $1.00 2 Left Door Lock Pawl \ $8.00 1 Right Door Lock Pawl / for PR 1 Right Door Latch EA $65.00 1 Left Lower Door Hinge EA $48.00 1 Right Lower Door Hinge EA $48.00 1 Left or Right Upper Door Hinge EA $45.00 1 Lower Door Hinge Roller Tension Repair Kit KIT $13.00 1 Door Hinge Repair Kit KIT $16.00 1 Door Striker EA $8.00 2 Window & Door Handle Retainer Cup EA $0.50 6 Left Door Window Regulator EA $60.00 1 Right Door Window Regulator EA $60.00 1 Vent Window Crank Pair PR $50.00 1 Screw-In Replacement Clip Studs SET $4.00 1 Windshield Wiper Arm & Blade Kit KIT $50.00 1 Wiper Motor 40-120 (Cardone) REMAN EA $75.00 1 Wiper Motor Transmission Retainer Clip EA $2.00 1 Backup Lamp Lens ea $14.00 1 Gas Door EA $30.00 1 (1964) Gas Cap - Vented EA $15.00 1 (1965-70) Gas Cap - Not Vented EA $8.00 1 Fuel Tank Straps (Surface Rusted) EA $30.00 1 1967 Wiring Diagram Book EA $5.00 1 Turn Signal Lever Cam Repair Kit KIT $6.00 1 Turn Signal Cancel Springs PR $2.00 1 Blower Motor Switch EA $55.00 1 Blower Motor Resistor EA $26.00 1 Stereo Front Speaker & Brackets EA $25.00 1 Fuel Pump w/Vent (Cardone) REMAN EA $42.00 1 Fuel Pump to Carb Line (S) EA $20.00 1 FT to Rear Fuel Line (S) EA $50.00 1 FT to Rear Vapor Line (S) EA $50.00 1 QuadraJet Choke Pull-Off EA 11.00 1 Choke Thermostat Housing, Coil & Rod EA $35.00 1 Cast Iron Thermostat Housing & Gasket EA $22.00 1 Thermostat Bolt w/Washer & Nut EA $4.00 1 1968-77 (11 Hole) Water Pump Divider Plate EA $20.00 1 Power Steering Pump Mounting Bracket EA $20.00 1 Throttle Cable EA $50.00 1 Blue Throttle Return Spring EA $6.00 1 Intake Manifold Gasket Set SET $20.00 1 65-67 Valley Pan Gasket EA $6.00 1 68-77 Valley Pan Gasket EA $5.00 1 D-Port Steel Exhaust Manifold Gasket Set SET $10.00 1 Starter Solenoid Heat Shield EA 13.00 1 Starter 323-256 (1893 723 GM) REMAN EA $90.00 1 Starter Solenoid D981 (1114458 GM) REMAN EA $45.00 1 1967-70 Q-Jet Throttle Shaft & Bracket EA $60.00 1 1967-70 Q-Jet Idle Mixture Screw EA $6.00 2 Carburetor Float EA $6.00 1 Crankcase Molded Vent Hose 90° EA $7.00 1 Steel Carb-to-Distributor Vacuum Line - Std. Trans. EA 12.00 1 "4-Q-66" Dated Ignition Wire Set SET 70.00 1 Delco Universal Plug Wire Set SET $30.00 1 Distributor Hold Down EA 12.00 1 Distributor Base Gasket EA $1.50 2 Distributor 30-1851 (Cardone) REMAN EA $70.00 1 Distributor Re-curve Kit (Points) KIT 10.00 1 Vacuum Advance VC-24A Standard EA $10.00 1 Contract Set EA 17.00 3 Condenser EA 8.00 3 Distributor Rotor EA 5.00 3 Ignition Coil EA $40.00 1 Distributor Cap EA 10.00 1 Standard Valve Cover Gasket Set (Rubber) SET $20.00 1 Outer Dip Stick Tube - w/o AC EA $25.00 1 Oil Pan Gasket SET $15.00 1 Cylinder Head to Block Alignment Pin EA $4.00 4 Pontiac V-8 Head Gasket EA $15.00 2 Fuel Pump Accentric - Light Surface Rust EA $35.00 1 Intake to Timing Cover Bolt & Clamp EA $8.00 1 Steel Engine Freeze Plug Set SET $11.00 1 Steel Cylinder Head Freeze Plug Set SET $6.00 1 Harmonic Balancer Bolt EA $7.00 1 Harmonic Balancer Washer EA $4.00 1 Black Nylon Compartment Strap EA $1.50 5 Non-AC Heater Core EA $80.00 1 Heater Blower Motor EA $30.00 1 Heater Box - Engine Side EA $30.00 1 Heater Hose to Head EA $12.00 1 Heater Seal Kit KIT $25.00 1 2" Fan Spacer EA $22.00 1 Radiator Cap EA $13.00 1 W. Washer Pump EA 1 Accelerator Pad Pin EA $2.00 1 Master Cylinder EA $50.00 1 Clutch Fork Boot EA $8.00 1 Clutch Rod Seal EA $8.00 1 Clutch Rod Seal Retainer EA $12.00 1 Shift Cable Floor Pan Grommet EA $5.00 1 Transmission Crossmember Insulator Brackets (Pr) PR $24.00 1 Rear Trans Mount EA $15.00 1 Hurst Shifter Mount Adaptor Plate EA $25.00 1 Bell Housing to Block Bolt Kit KIT $5.00 1 Flywheel Cover V-8 Standard Trans EA $30.00 1 Clutch Springs (2) PR $16.00 1 Clutch Fork Ball Stud EA $12.00 1 Clutch Countershaft Bushing EA $3.00 2 Clutch Countershaft Seal EA $3.00 1 Clutch Countershaft Bushing Spacer EA $5.00 1 Ball Stud Clutch Countershaft to Frame EA $10.00 1 Ball Stud Clutch Countershaft to Engine EA $13.00 1 Parking Brake Ratchet EA $80.00 1 Clutch Counter/Shaft Spring Clip EA $1.50 1 64-67 Ft Parking Brake Cable-Mt & Powerglide Tran EA $38.00 1 1964-72 Rear Parking Brake Cable EA $38.00 2 Mickey Mouse Brake Cable Clip EA $1.00 1 3/16" Push-In Brake Line Clip EA $1.50 1 1/4" Push-In Brake Line Clip EA $1.50 1 66/67 Brake Line Clip Set SET $28.00 1 Ft Brake Line Set (Steel) EA $50.00 1 Rear Brake Lines (R&L) (S) EA $20.00 1 Ft to Rear Brake Line (S) EA $40.00 1 Front Flex Hose Retaining Clip EA $1.00 2 Front Drum Brake Flex Line EA $17.00 2 Rear Brake Flex Line EA $20.00 1 Disc Brake Distribution Valve Bracket EA $15.00 2 Rear Brake Flex Hose Bracket (1968-72) EA $20.00 1 Rear Wheel Bearing EA $30.00 2 Rear Wheel Seal EA $8.00 2 Front Drum Brake Wheel Bearing Kit KIT $85.00 1 Clutch & Brake Pivot Shaft Bushing EA $3.00 1 Axle Flange Gasket EA $1.50 2 Ft Wheel Cylinder - Left EA $20.00 1 Ft Wheel Cylinder - Right EA $20.00 1 Rear Wheel Cylinder - R/L EA $15.00 2 1964-72 Front Drum Brake Spring Kit KIT $10.00 1 1964-75 Rear Drum Brake Spring Kit KIT $10.00 1 Rear Brake Shoe Guide EA $1.00 4 Parking Brake Spacer Bar EA $8.00 2 1964-72 Left Front Brake Adjuster Kit KIT $12.00 1 1964-72 Right Front Brake Adjuster Kit KIT $12.00 1 1964-72 Left Rear Brake Adjuster Kit KIT $12.00 1 1964-72 Right Rear Brake Adjuster Kit KIT $12.00 1 Upper Ball Joint EA $22.00 2 Lower Ball Joint EA $27.00 2 Inner Tie Rod End EA $65.00 2 Outer Tie Rod End EA $45.00 2 Tie Rod Adjustment Sleeve EA $10.00 2 Pitman Arm for Power Steering EA $65.00 1 Steering Center Shaft EA $100.00 1 Steering Idler Arm EA $40.00 1 Power Steering Pressure Hose EA $30.00 1 Power Steering Coupler (RAG Joint) EA $40.00 1 Upper Control Arm Bumper EA $5.00 2 Lower Control Arm Bumper EA $5.00 2 Rear Axle Bumper - Pair PR $15.00 1 Sway Bar Bushing - Pair PR $8.00 1 Sway Bar Bushing Retainer - Pair PR $10.00 1 1964-68 Front Drum Brake Wheel Stud EA $2.00 5 1965-77 Rear Wheel Stud EA $1.50 5 1967 Mark of Excellence Turquoise Foil Decal EA $4.00 2 Air Shock Decal EA $4.00 1 421-Tri-Power 425 HP Decal EA $4.00 2 Antenna Lead Firewall Grommet EA $15.00 1 Gas Pedal Rod Support EA $21.00 1 10-Bolt Rear End Cover Gasket EA $5.00 2
Just an old goat cruisin' in an old Goat........LIFE IS GOOD!! |
Chemnick
Chemnick
Another Bump
Merry Christmas!!! Chemnick
do you still have rear tail light bezels and lenses for a 1967 LeMans ?? Thank You
