Old 05-17-2020, 05:18 PM
Default Convertible rear trim for boot
Does the trim at the rear base of the top where the top boot slides into affix ? I assume you lower the top and there are screws that go through the trim into the pinch weld to secure it. Is this correct? Any idea what length or size these are?
Old 05-18-2020, 09:16 PM
I know a few guys here have verts. Mine was apart when purchased. I did drill out a left over stud or broken screw in one of the holes. Anyone??
Old 05-19-2020, 12:35 PM
rockys1970 rockys1970 is offline
Yes, The stainless pinch weld molding is held in place with small screws.There are 4-6 screws. They are very small in diameter maybe #6 or #8 and look like wood screws. They have a Phillips head with a taper under the head. They are VERY SHORT, maybe 1/4" long. This is from memory so there may be more than 6 screws.
Old 05-19-2020, 09:34 PM
Thank you.
