1969 400 Fan to Water Pump Bolts
I need a set of original fan to water pump bolts. 1-7/8” spacer with factory flex fan.
Thanks, Tom
1969 Firebird 400 Convertible "We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt "Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children |
Hello
I have a couple sets from the 2" ... they may be 1 7/8 .... spacer gotta check tomorrow
M and E foundry marks on mine ..I think on those long ones ... with 3 hash marks around the edge ... hardness marks Scott 2o6 465 9165 |
Scott,
I think they would need to be 2-1/4” to 2-3/8” long. Thanks, Tom
update
pictures
1....... overall 1" - 2 1/2 " spacers 2...... 1 7/8 spacer with 4 matching 2 3/8 bolts see drawing in upper right of the pattern and far right in picture 4 .. bolt heads shown 3..... another picture of picture 2 4.... RSC foundry ... 4 matching with a washer pulled from previous 4 bolts.. 2 3/8 also ..... these are seen on 68 9 q jet bolts and many short stubby bolts found on carb throttle bracket s and around the engine.. 5..... 2 1/4 bolt in the 1 7/8 spacer .... might be short scott68gto@comcast.net Scott 2o6 465 9165 |
Found them - thanks Scott!
None of those pictures of a spacer is the correct one for a 69 firebird. If he found what he needed, I need a set for the original style spacer.
he is after the bolts
not
the spacer spacer is/was for a 1 7/8" visual measurement as requested Scott he has the original solid round extention with the exposed bolt shank slot... just no bolts |
shipped
shipped
thanx......... |
If you have another set, I'd be interested. I have the correct spacer but need the bolts.
Dave pm sent |
