Old 08-04-2015, 03:22 AM
screamingchief's Avatar
screamingchief screamingchief is offline
Default '70 LeMans/GTO racecar
Strictly race only (not a street car),completely gutted interior,6 point rollbar,quick release steering wheel,poly racing seat,Autometer gauges (tach,oil pres,water temp,shift lite),aluminum dash & rear firewall,poly 16 gallon fuel cell,trunk mounted battery (w/box),glasstek lift off fiberglass front end w/5" cowl hood,quick R&R aluminum radiator,glasstek lift off fiberglass decklid,car currently has manual steering and manual drum brakes fr/rr.
Engine is a Pontiac 400 with #670 heads,bottom end has N 400 crank and TRW forged pistons/Eagle rods,SFI balancer and flexplate,Moroso deep oil pan,big Crower solid cam/lifters,HS 1.5 roller rockers w/Comp stud girdle,Edelbrock intake and Holley 800 dp carb,hedman headers,MSD ignition and plug wires,Meziere electric WP,JBP solid engine mounts and low mount alternator kit,among other items.
Transmission is an owner built TH400 with B-W clutches and a HD 34 element sprag and a RMVB,deep cast aluminum pan,CSR super shield,has a Redneck 3800-4200 9.5" stall converter in it now,shifter is a B&M pro-stick with a NIB cable.
Drivetrain has a Metco driveshaft loop,Southside Machine lower (rear) control arms (w/relocation brackets),the 4:10 geared 12 bolt rear end contains a spool,and moser race axles & C-clip eliminators,axles also have long 1/2" wheel studs,the wheels are weld drag lites (15x3 fr. & 15x8 rr.),w/Old MT 28x10.5 ET Drag Slicks out back.
To list all the parts this inlcudes would be like writing a book,fuel system was completely re-done,mostly just needs the wiring (and a few minor odds/ends) to finish the car & get it up and running.
Have a Texas title (and a signed bill of sale),but seeing as it's been a drag car for quite some time it has not been transfered by any of the previous owners over all those years,so take that for what it is.
I simply dont have the time for it right now and need it gone as it's in my brother's garage and I want it outta his way.
Asking $6500.00 obo.
Cash only,no thrid parties or brokers,will deal with buyers only.
Local pick-up only/buyer arranges any transportation.
Thanks for looking.
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 08-08-2015, 09:54 PM
Car is sold.
Thank you PY.
Bret P.
