I was wondering how the vacum advance hose is routed on a 66 tri power? Is it routed to a vacum port on the back of the center carb. Should it routed throgh ported vacum??
I tried to up load sams failed will send you an e mail the dist vacuum is ported off the carb with a reduction T port
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln "A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." — George Washington |
pic is 64 /65 center base
Pic is a friends 66 it looks like the vacuum is taken off the stud on the rear carb even thought the sams I sent you show all three years the same . they were GM bulitins too
pic is a 64 but 65 would be the same auto only 64 standard and auto would be like this at least until may this is an original April set up for a 4 speed
64/65 long tee ----66 short tee
so per this info my friends is not correct and has an A/C stud he's using instead of the correct T
If you take the "Bible" to be final answer. Somewhere it also says all tri 66's cam with the a/c stud even if no a/c,so buy a tee and plug the stud.?
sams
sams pt list If anyone would like a non reduced copy that could be read drop me a line
Thanks for the replies.... So vacum is basically routed off a port in the back of the center carb and the vacum is not ported off the manifold.
