Old 02-02-2005, 10:58 PM
boltbuster's Avatar
boltbuster boltbuster is offline
In a post about mini-starters, Coaster2002 referred to "the hot start problem." Is this a classic GTO difficulty? I just got my 67 HO last July. Once in a while, after a run of 6-7 miles or more, she wouldn't start for me right away. I figured that either I had some loose wiring, or that the starter solenoid was starting to go. Now I'm beginning to wonder. Is it just a matter of waiting for a cool-down? Any other ways besides installing a mini-starter to deal with the problem? Thanks.
boltbuster's Avatar
Old 02-03-2005, 05:13 AM
Brian D'Amico's Avatar
Brian D'Amico Brian D'Amico is offline
I tried to wrap it with that "high performance" heat wrap crap that you can buy. Don't waste your money.. It took me an entire Saturday to drop my starter, wrap it up and get it back in the damn holes. I am going to look into a mini starter this spring.
Brian D'Amico
Old 02-03-2005, 05:52 AM
gtomann67 gtomann67 is offline
PERFORMANCE YEARS SELLS A HEAT SHIELD TO SOLVE YOUR PROBLEM
Old 02-03-2005, 07:06 AM
Rugratman's Avatar
Rugratman Rugratman is offline
I actually fixed mine with heavier wire, and the heat shield.
From what I was taught on this forum, is when the engine get's reaaly hot, so does the battery cable. I installed 1 gauge wire and I wrapped the mini in some heat wrap(velcro style), and it fixed my problem. Kinda a blanket, took 2 min, to install from Summit.
I also installed a remote solinoid for this also, as I moved my battery to the trunck, and the voltage had a farther distance to go.
Try a heavier gauge cable from the battery to the starter first, somewhat inexpensive and easy to do. Then try the other methods. Hope this helps.
........I'm just learning as I go.......
Old 02-03-2005, 02:48 PM
6tee7goat's Avatar
6tee7goat 6tee7goat is offline
Send a message via AIM to 6tee7goat
With the HO manifolds you will need the heat shield although it really depends what temp. your car is running. My car ran hot and would occasionally have the problem even with the shield installed. Usually just letting the car cool off should be ok although I've heard that tapping the starter with a hammer sometimes works if you're in a hurry.
Old 02-03-2005, 05:51 PM
boltbuster's Avatar
Rugratman...I'm glad you mentioned the positive cable gauge and the wrap. Thanks. I also have a related question. Do you know, or anyone else, what the proper routing is for the positive battery cable on an HO? At the moment, mine drops directly from the battery to the front of the block, then straight back to the firewall and connections. Should it really run along the wheel-well, over the steering shaft to the back? I've been looking for pictures of a stock HO engine compartment that shows the cable routing and the location of the plug wire looms.
Old 02-04-2005, 06:12 AM
Phil Goat Nelson's Avatar
Phil Goat Nelson Phil Goat Nelson is offline
I had that problem and managed to fix it by just adding "starter shims" to adjust how the starter mates up with the block, and also wrapped the starter in heat sheild. Except for the initial adjustments in replacing the old shim with first one larger one, where the problem continued, then adding a second one, which fixed the problem, I never had any problems the rest of the summer. Total cost was about $3 for the shims and $15 for the heat shield.
____________________
PhilGoat
Old 02-04-2005, 09:38 AM
Old-Goat's Avatar
Old-Goat Old-Goat is offline
If memory serves me correctly, the positive lead from the battery on and HO car goes along the drivers side of the block, through a metal shield about 7-8 inches long that is attached to the driver side motor mount (this is behind the cast headers) to the starter. The starter soloniod also has a heat shield attached to it on the HO cars to help keep it cool.
http://forums.performanceyears.com/g...0484#740100484
Old 02-04-2005, 10:18 AM
boltbuster's Avatar
Thanks for the links, Gene...the pictures and diagram are very helpful.
Old 02-05-2005, 12:18 AM
baron_ baron_ is offline
Send a message via AIM to baron_
The hot start problem most people refer to is caused by the starter solenoid being overheated by the headers or HO manifolds.
These manifolds are obviously larger than the stock ones and run too close (almost touching) the starter, which makes it overheat and it won't start for a while....
A number of ways to solve it, but i'd recommend just getting a high torque mini starter
That's what i did, after trying the shield, which didn't work, the wrap, which didn't work...and both together, which didn't work (on my '67 HO).
The mini starter has never failed me and i love it to death
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
