Old 01-27-2015, 08:33 PM
cortcomp cortcomp is offline
They included what's left of a quart of paint they used to paint the hood tach and new front lower valance, so i have the recipe on that can fortunately. I'm not 100% sure it's a 100% match to the factory color without parking it next to another car that's original, but it seems to be very close to a GM color from the 90's that they modified slightly.
  #42
Old 01-27-2015, 08:51 PM
Ram4king's Avatar
Ram4king Ram4king is offline
The formula they have now days does not match an original paint car. It's a much nicer shade now than it was then. Nobody will ever know.
  #43
Old 01-28-2015, 10:46 AM
I figured it was along those lines, which is good because they'll be able to match it!
  #44
Old 02-21-2015, 09:43 PM
notime's Avatar
notime notime is offline
Or you just repaint it in lacquer to insure it matches the original paint in jambs.
WWW.SUPERCARCREATIONS.COM
  #45
Old 04-29-2015, 10:36 AM
ilo ilo is offline
I think you will need to build a car to suit your needs... the list is too long and you want it to be perfect... you will never find it...
Find a rust free car and build it to your specs.. it may cost more but at least it will be the way you want...
James
James Aiello
1968 GTO H.O. 4spd
  #46
Old 04-29-2015, 11:06 AM
Scroll back one page, found it awhile ago but just had to have minor stuff done (had the nose resprayed so it was perfect and had it fitted after the photos below, hood/nose alignment was bad and is great now. Just put a rebuilt shifter in to remove the slop and that's fantastic, converted the non-working clock to quartz, headrests recovered, putting a new dash flexible circuit in, starter wouldn't start hot. New starter solved that issue.) T
he minor stuff to take it from really very nice to omg that's a sharp GTO, great example. I want everything to operate as it should, firmly, quickly, like it was new (and it essentially is, under 1k miles on it since restoration.) Start up and go, no "warm up", as it should. Go straight, turn tight, stop quickly. Except for that flexible circuit waiting to go in to solve a temp light issue, i think i'm there and just need to really wash it and shine it after working and test driving it.
http://forums.maxperformanceinc.com/...4&postcount=32
ID:	396473   Click image for larger version
ID:	396474   Click image for larger version
ID:	396475   Click image for larger version
ID:	396476   Click image for larger version
  #47
Old 05-01-2015, 10:39 PM
Andretti's Avatar
Andretti Andretti is offline
Thumbs up
You've found yourself a nice car, it looks good. I think the prior owner made a good choice adding the hood tac and wood wheel. Agree with you about the nose fitment, quite noticeable. Congrats!
