One piece rear main install
Hi, going thru the directions and wondering for those that have installed the 1 piece seal what you're using for high pressure grease per instructions? Between the seal lips. I have some wheel bearing grease, but wondering if that would work or swell up the rubber?
Illinois Outlaw Gassers 6.27@107 9.97@131 |
The only grease I have is Amsoil synthetic wheel bearing grease and I installed a new one piece seal when I installed my new crank two years ago so I guess that’s what I used.
GTO George |
I used wheel bearing grease too.
My grease isnt synthetic , so wasnt sure if it would be ok or not. Was thinking long term about grease swelling rubber parts.
Wheel bearing grease used on probably 40 of them. No issues or leaks.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Just grease any good grease don't over think it..
Regular wheel Bearing grease is all that's needed, as this area in no way see's the load factor that the wheel bearings do, nor the potential heat build up from the brakes!
